MAP downpipe
Old Mar 22, 2009 | 06:45 PM
100%STEALTH's Avatar
MAP downpipe
hey does any body out their have the MAP integrated O2 housing downpipe. If so what do you think of it.
Old Mar 24, 2009 | 01:56 PM
no one
Old Mar 24, 2009 | 02:00 PM
boostedtres's Avatar
ive seen it online, looks like a clean, well built piece. prices extremely reasonable as well. your talking about the one that has the 02 dump incorporated right? like to see some opinions and results as well. get it and be the first to post!
Old Mar 24, 2009 | 02:01 PM
cthcky5's Avatar
https://www.evolutionm.net/forums/se...ousing-dp.html
Old Mar 24, 2009 | 02:05 PM
Kracka's Avatar
https://www.evolutionm.net/forums/se...-downpipe.html
I thought I posted a review of the one I helped install on my friend's car, but I can't find it. Either way, its a really nice piece that I plan to get for my car sooner or later.
Old Mar 24, 2009 | 07:16 PM
thanks everyone
Old Mar 24, 2009 | 07:20 PM
sspaladin28's Avatar
My review has wings
Old Mar 24, 2009 | 07:32 PM
xmaciek82x's Avatar
WOW, that's a nice piece. $300 for a DP and an o2 dump, not bad.
Old Mar 24, 2009 | 07:33 PM
yeah that helped me out a lot
Old Mar 24, 2009 | 07:55 PM
xmaciek82x's Avatar
Not sure if that was sarcasim or not, but here are my thoughts:
EPM o2 dump is around $260, plus a DP another $150+ depends what you go with.
Or you can get APM for $300. Its bigger pipes man, there is not going to be difference in performance between EPM plus a seperate DP or MAP piece.
The only down size I see with the MAP piece is the if you ever need to take off your DP to do any work under the car that requires you to take out the DP, you will have a harder time unbolting a o2 housing then just a DP.
I have a post right below yours about the EPM dump I just installed, the reason I went with EPM is because I already had a DP. If you have neither and what to save money, go with MAP. Both stores have GREAT customer service. I order from Adam at MAP ALL the time, and Q from EPM is also great.
Old Mar 25, 2009 | 01:41 PM
Aby@MIL.SPEC's Avatar
I like the look of the map integrated dp.....
I would have bought this instead, if it was available at the time.
Old Mar 25, 2009 | 01:51 PM
it wasnt sarcasim i was directing that post to sspaladin28 and yeah i dont have neither so i am going to go with the map to save money thanks.
Enyth
Oct 10, 2016 03:38 PM
Evo526
Apr 4, 2015 03:36 PM
GsrJake
Nov 14, 2012 07:21 AM
MichaelUWright
22
May 18, 2011 02:40 PM
Fidget253
Jun 10, 2010 06:58 AM
