Cobb Stage 2 map quesitons
Old Mar 29, 2010 | 05:14 PM
Fidget253's Avatar
Can you run the stage 2 map with just a 02 downpipe and test pipe, but on the stock exhaust and have it run alright or no?
Old Mar 29, 2010 | 05:22 PM
monkey_187's Avatar
I dont think it will cause of the way the inside of the stock muffler is made. I could be wrong though.
Old Mar 29, 2010 | 05:24 PM
monkey_187's Avatar
You might also want to check this out
https://www.evolutionm.net/forums/ev...ere-merge.html
Old Jun 4, 2010 | 01:34 PM
slebo3213's Avatar
Still curious about the "Full TBE" requirement. I'm sure there are some aftermarket exhaust systems out there that are as restrictive, if not more, than the stock system. To just say any full TBE will do seems overly simplistic.
Is it safe to assume that the real restrictor is at the cat, and running the stock downpipe and muffler is fine as long as you have replaced the oem cat with a hfc or tp?
Old Jun 8, 2010 | 02:09 AM
steven88's Avatar
i would say yes, the real restriction is the stock cat....then catback exhaust...then o2 downpipe
just for reference...i ran a rexpeed o2 downpipe and ultimate racing test pipe with the stock catback on cobb stage 2 91oct....ran completely fine with no knock...i also ran some datalogs on cobb stage 2 91oct with a completely stock tbe...and it ran fine too
just go ahead and flash it and run some logs..if your car can't handle it, flash back and wait till you get a full TBE
Old Jun 9, 2010 | 09:54 AM
305EVOx's Avatar
Yes, I have been running the Stage 2 w/ AMS intake 93 Oct map since the day i got my Cobb AP. And all i have is of course the AMS intake, DP and Test pipe.
I haven't had no problems or CEL, and the car is running good.
Old Jun 9, 2010 | 05:23 PM
COBB Tuning's Avatar
The restriction for stage 2 is not generally the catback section but the downpipe. If you have a test pipe and or a shorty downpipe, you should be able to run stage 2 without issue. The only other restriction to what type of map you can run is your intake!
Travis
COBB Tuning
Old Jun 10, 2010 | 06:36 AM
slebo3213's Avatar
What about gauges for stage 2? Is it recommended that you have a boost gauge, or anything else, so that you can monitor performance while driving?
Old Jun 10, 2010 | 06:58 AM
MikeTheGreek's Avatar
^^ its always a good idea to see if your getting spikes and make sure your a/f ratios arnt dangerously low If you have the money I would go for it. This is the first thing I would do Love watching the turbo spoooool!
AGinHD
Jul 10, 2013 10:41 AM
userwave
Cobb AccessPORT
Apr 20, 2012 11:50 AM
EvoXRed
Jul 5, 2011 07:34 AM
JebusMKIV
Apr 1, 2010 07:12 PM
3dman1
May 3, 2009 12:13 PM
