Wicked Twin Disk Rattling
Old Apr 8, 2009 | 03:07 PM
  #31
scherejs's Avatar
Well I kind of found out what was wrong with mine. Seems the tranny was about to go out. I lost reverse and barely have 1st gear now. As soon as I start the car it sounds like there are ball bearings rattling around, and it's very loud. It goes away as soon as I push the clutch pedal in. I towed the car to a shop last night and they are going to take a look at it next Monday. Looks like it'll be a Shep or Bushwacker tranny for me
Old Apr 8, 2009 | 03:52 PM
  #32
EJEvo's Avatar
Originally Posted by Floyd is Pink
now are you 100% sure it's the clutch?
Absolutely it could be something other than the clutch - definitely a good avenue to pursue. But the OP sounds like he's checked on some of the likely options before going this route.
Old Apr 8, 2009 | 05:09 PM
  #33
Boltz.'s Avatar
FCOTM Winner
At this point, it seems that first gear is the problem. Because of that, I have removed the trans and sent it to John Shepherd. I am positive it wasn't some other part of the car rattling. Thanks.
Justin
Old Jul 5, 2009 | 11:53 AM
  #34
downshift411's Avatar
i have that tob ticking noise. it only occurs while its full warmed up. symptoms is as same as the others, engage the clutch noise goes away or gear(s) engaged. let go of the clutch in neutral ticking just keeps on going. its embarrissing honestly...tob would be the prob...but with a new tob the clutch would be the culprit or installed wrong.
Old Jul 5, 2009 | 02:50 PM
  #35
CO_VR4's Avatar
Originally Posted by Boltz.
I will. The funny thing is, yours was loud with the clutch pushed in, but was quiet when the clutch was not pushed in, when it was brand new.
Mine was loud and rattly with the clutch not pushed in immediately after installation. Not sure what to think. I will let you know if I find an answer, although it might be a different cause.
Yours might be first gear, but in most cases, I wouldn't be surprised if the rattle is related to your throw-out bearing. That's a classic symptom -- rattles when engaged, stops when you feather the clutch a little, putting pressure on it...
Don't blame the clutch until you check out the TOB.
deeman101
60
Jul 18, 2013 01:29 PM
snafufx
15
Mar 14, 2012 09:28 AM
delongedoug
May 21, 2010 04:20 PM
WickedWhtMR
24
Oct 9, 2009 11:00 PM
robboost
Jul 8, 2009 10:08 AM
