cam install = no boost?
Old Mar 28, 2009 | 02:30 PM
MIVEC 4G63's Avatar
i just installed brian crower 272s in my evo 9. i also put in an o2 housing and downpipe combination. i have a manual boost controller thats set to maximum and im not seeing anymore than 7-8 lbs of boost, but i just ran the car a little harder and i got to see as much as 15psi but its very very sluggish and not responsive. Can anyone help me?? I still haven't tuned the car btw.
Old Mar 28, 2009 | 03:32 PM
W_evo8's Avatar
Follow the vacuum line from your bov to the intake manifold, that may have came off.
Old Mar 28, 2009 | 03:35 PM
Wicked E's Avatar
Crowers are the WORST cam for the Evo 9.
-E
Old Mar 28, 2009 | 05:08 PM
MIVEC 4G63's Avatar
i ran the boost controller correctly. im pretty sure i did and i did it again to double check. i just drove the car again and stepped on it so i was able to get 15psi but it took for ever to get there. im also getting a checkengine for cam angle sensor.
Old Mar 28, 2009 | 11:22 PM
DDATuned's Avatar
It sounds like you have a boost leak in one of the lines leading to the mbc..
As far as the cel, if you cam angle sensor didnt work, the car would not start. Did you try to crank the car with it unplugged to check something?
Old Mar 29, 2009 | 06:47 AM
MIVEC 4G63's Avatar
no i havent. im still working on this boost issue. did you mean vacum line is leaking?
Old Mar 29, 2009 | 09:58 AM
20gmr's Avatar
Having a cam sensor code is not good. What is the exact code?? IX's have two cam sensors and the code will determine wich one has the issue. when you put the trigger wheel on the en of the new cam did you make sure you are not 180 degrees off.
Old Mar 29, 2009 | 10:02 AM
Evoryder's Avatar
probably installed the cam 180 degs off. 7lbs of boost is a killer leak of some sort...when taking off the valve cover you may have not connected all your vaccum linesl, possiblity.
Old Mar 29, 2009 | 01:02 PM
MIVEC 4G63's Avatar
the cam fits in the sprockett only one way though. how is that possible?
Old Mar 29, 2009 | 04:51 PM
MIVEC 4G63's Avatar
im told that the car wouldn't start or have a real tough time starting. my car starts on the money. could that ring by the sensor be off?
Old Mar 29, 2009 | 07:39 PM
20gmr's Avatar
That is what I was sayin......its called the trigger wheel. You probly have that 180 off
Old Mar 29, 2009 | 07:45 PM
YzBrad99's Avatar
put in the stiffer MBC boost spring
Old Mar 29, 2009 | 07:56 PM
N3VO's Avatar
he has his turned all the way up that would be one crappy spring if it was only going up to 15 psi
Old Mar 29, 2009 | 09:56 PM
justa4banger's Avatar
my forge boost controller came with a 15 psi spring so i changed it out and it fixed my problem...
Old Mar 29, 2009 | 10:02 PM
VtexGt3's Avatar
sounds like a big boost leak. if you have a big leak somewhere the stock turbo will only boost to roughly that level and refuse to go any further. it happened to me when the IC pipe that is recirced from the BOV came loose. wouldn't go past 12, 13 psi. checked for leaks over and over or get a leak test done. will save you tons of time.
