no boost slow boost
Old Mar 29, 2009 | 07:32 PM
  #31
MIVEC 4G63's Avatar
i dont know anymore man, would the amount of boost be identical every time. car never acts funny when i rev it, it feels like my exhaust is sealed half closed or something. boosts so slow but car is very consistant, i don't know if it would act this way if that was the case.
Old Mar 29, 2009 | 07:54 PM
  #32
N3VO's Avatar
well start putting psi in and if you cant get it up to that much psi you know you have a big leak licp is usaually a big one i would check that out.
Old Mar 29, 2009 | 07:58 PM
  #33
sparky's Avatar
Just try this: Disconnect the MBC. Plug the hose ends that are uncapped when you disconnect said MBC. Run a short segment of 4mm vacuum hose directly from the compressor housing discharge nipple to the port on the WGA canister.
Now, try increasing wastegate pressure by rotating the turnbuckle on the threaded end of the actuator rod. Rotate it inward toward the WGA's canister, which shortens the rod and thereby increases actuator spring pressure.
Pm me for specific details, or if you have any questions whatsoever on this proceedure.
Old Mar 30, 2009 | 03:24 PM
  #34
MIVEC 4G63's Avatar
still nothing guys
Old Mar 30, 2009 | 03:39 PM
  #35
N3VO's Avatar
you boost leak tested it and it held 25 psi with no problem?
Old Mar 30, 2009 | 04:01 PM
  #36
steevo 8's Avatar
video a pull, put it on youtube, send the link. alot easyr with some sight on the problem...
Old Mar 30, 2009 | 04:40 PM
  #37
MIVEC 4G63's Avatar
ok ill do that.
Old Mar 30, 2009 | 04:45 PM
  #38
inco9nito99's Avatar
1.) Not trying to hate, but BC cams suck for IX's.
2.) Make sure they're degreed at zero.
HTH some.
Old Mar 30, 2009 | 04:49 PM
  #39
Wicked E's Avatar
HTH some.
This....
-E
Old Mar 30, 2009 | 06:29 PM
  #40
MIVEC 4G63's Avatar
how do you degree them? the yhave to be pulled again? here this is the crapy vid i recorded.
http://www.youtube.com/watch?v=JCqxAAvevT0
Old Mar 30, 2009 | 06:40 PM
  #41
Wicked E's Avatar
Dum Dee Dum Dum....
Cam timing is off and/or your cam sensor is 180* out.
-E
Old Mar 30, 2009 | 08:03 PM
  #42
MIVEC 4G63's Avatar
the timing marks are on the money.
Old Mar 30, 2009 | 08:06 PM
  #43
Wicked E's Avatar
Down below too? Highly doubt you checked all the timing marks. Trust me, half a tooth makes a HUGE difference. Only way to verify is to take the front cover off and line up all the marks.
-E
Old Mar 31, 2009 | 10:13 AM
  #44
steevo 8's Avatar
your in nyc. i would bring is to a shop over the bridge call it a day...
Old Mar 31, 2009 | 10:16 AM
  #45
Do I win a prize -E? .
