GT35r low end power
Old Apr 2, 2009 | 12:55 PM
  #31
AlainD's Avatar
I use 95, i dont think it would be too easy to import e85 here, also i dont think i can get meth refills here lol
Old Apr 2, 2009 | 01:01 PM
  #32
cincy's Avatar
A billet wheel, either FP or PTE would be my choice. The Precision should be a little cheaper. Increase compression is another option, but im sure you dont want to open up the motor since stroker is out of the question
Old Apr 2, 2009 | 01:39 PM
  #33
AlainD's Avatar
I'd love to have a stroker kit, but cannot afford to spend that amount of cash at the moment...
Old Apr 2, 2009 | 01:41 PM
  #34
cincy's Avatar
did you ever find out what hotside you have? .63 or .82?
Depending on which style you have its either ~$200 or $400
Old Apr 2, 2009 | 01:54 PM
  #35
AlainD's Avatar
im @ work right now and wont have a chance to check... tomorrow in the morning ill take a look and find out
Old Apr 2, 2009 | 01:58 PM
  #36
FQ4OO's Avatar
Originally Posted by whoang40
27psi by 3800? I can only hit 24psi with my green at 3800 rpm. It probably has more to do with your 2.3L. Besides he mentioned that a stroker kit is not an option for him. Do you have a plot of your boost graph, that's some crazy spool? BTW you should try out the twin scroll manifold and hotside to help your spool including adjustable cam gears.
here ya go. Mines a 5 speed box...
Boost was unstable on that run , car in the shop getting a few more mods and some fine tuning. Will post an updated graph onces its all sorted.
Old Apr 2, 2009 | 02:02 PM
  #37
FQ4OO's Avatar
Originally Posted by crcain
What gear is that and was that on a dyno or the road?
Post a datalog on the road because that would probably be the fastest spooling 35r I've ever heard of and would like to see a boost plot. I'm on a 2.4 with .63 a/r HTA and make 30 psi at 4500 rpm in 4th gear.
Run was forth gear, in 5 speed Evo VIII.
Im very happy with the spool, im installing M&W Pro14b and coil upgrade, and fuel system upgrade because on that run i was starting to run lean.
But yeah, very happy with the setup. Pretty sure the .63 is almost out of puff at 27psi.... am going to keep turning up the boost til it stops making power, then turn it down 1-2psi to keep it efficient.
Old Apr 2, 2009 | 02:19 PM
  #38
crcain's Avatar
Are you on the 5-bolt .63? If so I've ran that to 41 psi. If you are on a 4-bolt maybe you are right and that is why you spool so well. It is said the .63 5-bolt is larger than the 4-bolt .63.
As for spool, dyno's can be deceiving would be interested in a datalog on the road.
Old Apr 2, 2009 | 02:24 PM
  #39
JEFFREYCASTGSX's Avatar
Cams will NOT help with spool, only cams that sometimes do are small cams like 264's.
Old Apr 2, 2009 | 02:28 PM
  #40
High_PSI's Avatar
The .63 would do the most for spoolup followed by a proper retune with a lot of attention to timing to get the spoolup under control.
Old Apr 2, 2009 | 02:34 PM
  #41
FQ4OO's Avatar
i believe its this one.
http://www.turbobygarrett.com/turbob...R_714568_7.htm
will confirm with my mechanic.
Old Apr 2, 2009 | 02:44 PM
  #42
FQ4OO's Avatar
I'll try to get a datalog done soon, on the road watching the boost gauge, im confidient the dyno is reading correctly. before 100kph ~62mph, the car is pulling hard in 4th.
I was thinking the 35r would be too laggy but im pleasently surprised. Very good setup for combination of street/drag/circuit
SLVRNBLK
Jun 18, 2015 06:44 PM
Martin@AMS
246
Apr 24, 2015 12:32 PM
JDM EVO PANAMA
Jan 5, 2011 07:08 PM
AlainD
Jul 22, 2010 03:26 PM
Darklancer
Southeast Region
20
Feb 5, 2004 07:04 PM
