Front O2 Sensor replacement Q?
Old Mar 31, 2009 | 09:47 PM
fixem2's Avatar
Recently replaced my front O2 sensor with a universal 4 wire sensor. After getting other work done to the car, I started logging with EvoScan and I am showing a 0 in all LTFT's, O2 Sensor = 0 V and the STFT shows 25 at warmup and 5 when warm and at idle. I have no CEL showing at this time and the car is running rich according to the WB.
Now other mods where done that could cause the rich condition, but I was wondering if the wires could be reversed when I connected the universal sensor.
Thoughts? Anyone connected a universal front sensor and have the right layout for the wires?
THanks.
Old Mar 31, 2009 | 09:50 PM
whoang40's Avatar
I've connected a universal O2 sensor. Haven't had any issues with it. The only wires you could possible switch is the 2 black wires, which are interchangeable. They are only heater core wires. Other than that did you accidentally swap the white and blue wires? That's wouldn't be good and you would throw a code right away. BTW this is the sensor I installed. http://www.oxygensensors.com/showpic...0&pkey=1431371
If you're not throwing a code, it might be something else causing your rich condition. My only advise is to log it on Evoscan to see your afrs.
Old Mar 31, 2009 | 09:52 PM
fixem2's Avatar
I was thinking the same thing, but no CEL.
Old Oct 25, 2009 | 08:17 AM
Fast_Freddie's Avatar
Veteran: Navy
Sorry to bump this old thread, but I am having the same exact problems... my fuel trims are reading but right after start up, STFT goes to 25 for about 15 seconds then slowly creeps back down and is fine...
Old Oct 25, 2009 | 10:10 AM
Gary@MellonRacing's Avatar
r u using bosch model number 15730
Old Oct 25, 2009 | 05:51 PM
Veteran: Navy
I think so... I threw the box out a few weeks back as I assumed it was working okay...
GodRealm06
Jul 9, 2015 02:36 AM
kanyonkid
14
May 29, 2008 09:21 PM
drucea
Lancer Troubleshooting
Mar 13, 2008 02:09 PM
KartaRailed
Jun 28, 2007 09:24 AM
xcuzme
Feb 21, 2007 06:55 PM
