t-case seal!-t-case leaking fluid. SUGGESTIONS?
Old Apr 4, 2009 | 10:53 AM
barneyb's Avatar
I'd suggest trying another seal and applying RTV to the perimeter of the seal before inserting it. Also, use a driver for the seal. A large pipe nipple ground flat on one end and with a cap screwed on the other makes a good driver. The pipe should be large enough in diameter to rest on the metal part of the seal. Take the seal with you when you visit the hardware store.
Old Apr 5, 2009 | 04:28 PM
esevo's Avatar
I too am having this issue, its really pissing me off.
Old Apr 5, 2009 | 06:35 PM
allday10sec's Avatar
thanks buddy yes th pipe is a good idea! i used the cup off my axel and yes i had atv blue gasket sealer in my hand for the pass few days trying to figure out if i wanted to use it or not haha! ( in my head im like the factory seal should work with out any modding) but i messed up my seal so i will trow in a new one then bead the atv around the outer part for a good seal!
anyone know whats this hole do? is it a vacume.
its a little hole
Old Apr 5, 2009 | 06:36 PM
the little hole at the top in side where the seal fits!
Old Apr 5, 2009 | 06:42 PM
idriveanevo's Avatar
did you pull the axle out in the last pic to replace the seal? i would put the silicone on the seal seat before you install it
Old Apr 5, 2009 | 08:54 PM
yes i did! what was that ?
should intsall the new seal then bead the silicone around it so it attach;s to the seal and t-case wall!?
or do you mean put silicone on the seal then install it in the -t case?
Old Apr 23, 2009 | 03:18 PM
hahah snap i chnaged the seal 3 times already.
after i adjust the seal from in and out i ripp it so i get a new one.
still leaking
so i tryed changeing my inn cv joint(92 dimante cv inner axel workes) because the surface of it that meets the seal is ding up.
steal leaking.
so im try and get another seal and do i tone more time beofre i give up and give it to works!
really this is dumb i feel useless
Old Apr 23, 2009 | 03:49 PM
GTijoejoe's Avatar
Originally Posted by barneyb
Thanks for the picture but it is blurry. If you are meaning the green part that is the outer housing for the CV joint. I think I see a dent on the backside that looks like somebody applied too much force when trying to remove the axle. If it is not deformed on the inside it should be okay. Otherwise, replace it.
The axle seals are easy to damage when inserting the axle. Take special care not to allow the splines to touch the seal.
Yeah blurry picture. The seal on the TC is to keep debree out with the assistance of the cup on the axle, and to keep the oil in the TC. This is typical on almost any diff. case that doesn't have bolted axle cups.
My seal was leaking, I replaced it and no problems anymore. Be sure that when you replace the seal and install the axle, that the axle goes completely in the TC. The axle has a outer race that seals against the inner part of the seal, if these two do not sit properly it will still leak.
Old Apr 24, 2009 | 11:35 AM
yeah thats what i figured, thats why i wnet and chnaged my inner cv joint because the surface of it that meets the inner part of the seal was dinged up and not smooth.
im going to try again today thanks for the help
Old May 2, 2009 | 07:52 PM
TyeVO's Avatar
whats the part number for this seal my passenger side leaks like a **** out of the seal
Dallas J
Sep 10, 2019 11:45 AM
stunna2o1
12
Jan 19, 2016 11:44 PM
cash
Mar 18, 2010 05:20 PM
Agent-Smith
Aug 17, 2007 11:26 PM
elhalisf
Sep 22, 2006 10:57 AM
