Problem with turbo need help !!!
Old Apr 3, 2009 | 08:18 AM
BadBoy818_818's Avatar
So yeah i finally fixed my ride everythings ok except one thing im not sure whats up put i think its a boost leak
so this is what happends when i drive my car hits boost (Its an MR btw) and it only goes up to 0.8(12psi) bars instead of doing 1.25(18psi) i tighted all the intercooler pipes , but still the same what could be wrong?
Old Apr 3, 2009 | 08:23 AM
yuronich_b's Avatar
Sounds like its stuck on wastegate pressure?...all lines to your mbc or boost solenoid in tact?
Old Apr 3, 2009 | 08:27 AM
think so i jus recently installed a greddy ebc , so it could be possiable one of those hoes flew off?i think i check that but i'll check again and update but in the mean while if you guys might have any other thought why my car is doing this plz post
Old Apr 3, 2009 | 08:31 AM
evo unknown's Avatar
Does this happen during all accerlations? Or just the first couple minutes of driving? After a couple minutes can you hit full boost?
Old Apr 3, 2009 | 08:47 AM
AWD_Terror's Avatar
remove the EBC out of the loop and see if it does it.
Old Apr 3, 2009 | 01:50 PM
no , i cant' its the same at all boosts
Old Apr 3, 2009 | 01:55 PM
what do you mean remove it out of the loop? as in put it back to stock?
also since mine is an MR i already have a boost gauge installed so what i did was i connected the ebc boost hose to the same boost gauge hose , thats ok right?(i know it is just making sure)
Old Apr 3, 2009 | 02:12 PM
also , i would like to know , what happends if im not useing the EBC right?(NO IM NOT BOOSTING AS HIGH AS I CAN OR ANYTHING THE CAR ISNT TUNED SO IT WONT BLOW ANYTHING UP) ive read that no matter how low you put it it wont boost less then its stock boost
Old Apr 4, 2009 | 12:24 AM
bump!
Old Apr 5, 2009 | 12:26 AM
i messed with the boost controler a lil and i guess that was the probleme i jus have to get it set up right i guess
Old Apr 5, 2009 | 12:29 AM
SLO-EVO's Avatar
you have to set the EBC for you boost... if you adjust the settings and you still are only boosting 12 psi, youre on wastegate pressure, and need to check your EBC...
ddawg1130
Evo X Dyno Results
13
Oct 22, 2013 09:54 PM
TommiM
Apr 14, 2013 02:36 PM
818evo9
Jan 5, 2010 11:12 PM
BadBoy818_818
19
Jan 30, 2009 07:10 AM
BadBoy818_818
Jan 5, 2009 03:21 PM
