Car sounds like a WRX?
Old Apr 4, 2009 | 11:21 AM
Anarchy99's Avatar
Best way to put it and I have been searching the forum, seems others have had similar issues but I cannot tell if mine is related. Ill be driving or sitting at a light and the car starts to sound kind of like a boxer engine or something and it will be difficult to accelerate. Its throwing no codes, compression and leak down were good so I feel like it should be a supporting mod like maybe a bad fuel pump or something? Wondering if others have experienced this because it sounds much like the p0300 code or whatever but there is no check engine coming on.
Old Apr 4, 2009 | 01:28 PM
sonicnofadz's Avatar
Check for vaccuum leaks. Do a boost leak test.
Old Apr 4, 2009 | 01:41 PM
Anarchy99's Avatar
Its possible but its just weird it comes and then goes as if nothing. A boost leak has its own special feeling this is a different feeling it really feels like its missing or something but that would be constant usually. Boost gauge reads -21 vac at idle.
Old Apr 4, 2009 | 01:43 PM
jamevo8's Avatar
My car sounded like that.. the exaughst was hiting the lower strut bar
Old Apr 4, 2009 | 01:45 PM
Liqquid's Avatar
Mine was a snapped valve spring.
Do you have a wideband?
https://www.evolutionm.net/forums/ev...baru-help.html
https://www.evolutionm.net/forums/ev...e-springs.html
Old Apr 4, 2009 | 01:50 PM
Anarchy99's Avatar
Hmm interesting reads, it has brand new supertech valve springs and retainers
Anarchy99's Avatar
I wish it was only exhaust hitting strut bar that would save loads of time and money hahah
Old Apr 4, 2009 | 03:12 PM
ppayer38's Avatar
Sounds like a misfire to me but i would say it is caused by Vaccumm if anything if it only happens when car is idling.......
Old Apr 4, 2009 | 03:14 PM
diiirk@AwdMotorsports's Avatar
check for vacuum leaks, make sure all coil packs are in correctly, make sure maf sensor is plugged in right (unplug and plug back in).
Old Apr 4, 2009 | 03:17 PM
eve-slow's Avatar
Sounds like ignition.
Old Apr 4, 2009 | 03:18 PM
SRT-TO-EVO's Avatar
Exhaust leaks?
Old Apr 4, 2009 | 03:20 PM
boosted2x2's Avatar
sounds like a random misfire i would check plug wires, spark plugs, coils, and harness for loose connections, injectors also in that order.
Old Apr 4, 2009 | 03:21 PM
Anarchy99's Avatar
It randomly happens while driving and then just goes away. Trying to narrow it down and it's frustrating!
Old Apr 4, 2009 | 03:22 PM
Anarchy99's Avatar
So far I've done new plugs, injectors and lifters in case one was bad
Old Apr 4, 2009 | 05:52 PM
RoadSpike's Avatar
Mine did that when an injector clip was loose
You probably want to just check spark since you've changed all injectors
