Having issues!!!!!!!!!!!!!!!!!
Old Apr 5, 2009 | 08:34 PM
808boost's Avatar
delete problem solved..................
Old Apr 5, 2009 | 09:07 PM
Venividivichi00's Avatar
what kinda tuning program are u running on the car?
Old Apr 5, 2009 | 09:14 PM
C130flyer's Avatar
this may sound really dumb but the older DSM's required a fully charged battery to start correctly I would look into it. You never know, especially if the car had a lot of down time during you build up, the battery could have lost some charge.
just my .02
Old Apr 5, 2009 | 09:21 PM
lillev23's Avatar
Check your gaps, and you might have some bad gas
Old Apr 5, 2009 | 09:23 PM
str8kor's Avatar
check your tune?
Old Apr 5, 2009 | 09:26 PM
808boost's Avatar
i have a ecu flash
Old Apr 5, 2009 | 09:59 PM
dancarroll0283's Avatar
The cam sensors on both the intake and exhaust cams may be off..... You can either be dead on on the timing there, or 180* off...... Try rotating each 180* and go from there.....
Old Apr 5, 2009 | 10:11 PM
808boost's Avatar
thanks we checked that also already. is there a way to adjust it???????
Old Apr 5, 2009 | 10:13 PM
nope..... at least not that i'm aware of.....
Old Apr 5, 2009 | 10:14 PM
what kind of injectors did you get??
Old Apr 5, 2009 | 10:23 PM
808boost's Avatar
put the stockies back in with my stock map
Old Apr 5, 2009 | 10:27 PM
so with the stock injectors you still cant get it to start??
Old Apr 5, 2009 | 10:29 PM
808boost's Avatar
correct............
Old Apr 5, 2009 | 10:31 PM
as far as the cam timing.... the marks on the cam gears line up with the marks on the valve cover, and the the dowel pins are facing up??? I know that its easy on the 9's to have the intake cam off 180 as well....
Old Apr 6, 2009 | 04:01 AM
Evo8Emperor's Avatar
make sure you put your immobilizer code back in your new flash. Sounds to me like the immobilizer isnt in.
