BlowOff Valve: Have Recirc or Move MAF sensor
Old Apr 6, 2009 | 07:13 PM
timskyline86's Avatar
im planning on buying an evo and it came up in our dicussion. ok so heres the deal. me and my friend have been aruging over this.
He says if you have a turbo putting in a blowoff without a recirc will make the engine run rich, i said this is only the case because the MAF sensor is behind the blow valve and will give a false reading. He said its better not to have a valve at all which i said is just plain stupid if you plan on having a big turbo and for long term use and opt performance.
My solution is you can have a recirc at 50-50 and move the MAF sensor after the valve for opt performance. ofcourse he doesnt think so. I ask my fellow evo enthusiast for their wisdom or a better solution.
Old Apr 6, 2009 | 08:47 PM
njvlllrs's Avatar
a "blow through maf" is what you speak of i imagine ? not really a good idea for any evo... many will agree im sure... the stock recirc valve still works in excess of 400+hp on my own car... if thats not enough i would suggest removing the maf and converting to some type of speed density sensor (MAP or manifold absolute pressure) there is many advantages of this setup especially if you speak of a "big turbo"... but in turn this also involves some type of engine management ... hope that helps...
Old Apr 6, 2009 | 08:53 PM
Boost3dxEvO's Avatar
Keep the bov recirculated... if you opt to delete the maf (which has been proven to make a TON of power with) then do it right and go with an EMS like AEM with speed density.. Do not use a blow through system, they are no better than stock maf.. and just more hassle to tune..
Old Apr 6, 2009 | 10:32 PM
Xearo's Avatar
when u say recirculated bov, do mean that it doesnt dump to atmosphere? There would be know "Woooosh" sound that way right? Stock, we have a diverter valve which reciculates. What is different between this and the recirculated BOV?
Also, ii have heard claims that a cold air intake can cause problems, as the maf gets confused and provides inaccuarate readings.. is there any truth to that?
Old Apr 6, 2009 | 11:47 PM
VRSF Tiago's Avatar
Most aftermarket intake pipes (ETS & Buschur) affect the maf readings which will cause inconsistent readings at idle.
Old Apr 7, 2009 | 01:31 AM
Toxin's Avatar
keep it recirc or go with a standalone like previously mentioned.
Old Apr 7, 2009 | 01:35 AM
VRSF Tiago's Avatar
Many people have success with the GM maf and it works well. There is also the option of running speed density on the stock ecu. There's a nice long thread in the ECUFlash section of the forum
Old Apr 7, 2009 | 09:34 AM
Xearo's Avatar
speed density = map?
i thought u had to run a seperate ems to interprate the the map signal?so if it just changes the idle, that doesnt sound like a bad problem, but when i move up to UP michigan, where it get to -Farenheight temps on a regular basis during the winter, is there any chance that it will misread and overlean and blow? ( does the evo compensate for temperature?)
bh117
Apr 9, 2015 11:14 AM
paintball272003
For Sale - Cars For Sale
Jan 19, 2015 07:29 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
timskyline86
24
Apr 9, 2009 07:27 PM
