What oil to use?
Old Apr 7, 2009 | 07:35 PM
turbodreamz21's Avatar
What oil to use?
hey guys
i have a 03 evo 8 built 2.0 running a gt35r. Have 500whp. looking to do oil change, whats everyone running for these type of numbers?
idk if i should stick with mobile 1 5w30 full synthetic or switch to something thicker?
thanks
Old Apr 7, 2009 | 07:36 PM
whoang40's Avatar
I use Mobile 1 10w30 like it says on the manual and oil cap.
Old Apr 7, 2009 | 07:39 PM
my friend told me to use ROYAL PURPLE 10/40 or 20/50 ?
Old Apr 7, 2009 | 07:43 PM
recompile's Avatar
I'm currently using Mobil 1 0w-40. Great in cold starts and holds up well in high heat... only $7/qt @ AutoZone.
Old Apr 7, 2009 | 07:46 PM
thanks Christian ill prob go to autozone tom and pick some up with a new filter.
Old Apr 7, 2009 | 07:53 PM
cij911's Avatar
Mobil 1 ...Factory recommends Mobil 1 10w-30, but if you are in EXTREME cold you could go with a 5W - 30....For Mass. I would just stick with Mobil 1 10w-30 (like the factory recommends).
Old Apr 7, 2009 | 07:55 PM
N3VO's Avatar
mobil or amsoil
Old Apr 7, 2009 | 07:59 PM
huevosrancheros's Avatar
Old Apr 7, 2009 | 08:12 PM
Skott2k's Avatar
i use amsoil 10w 30
Old Apr 7, 2009 | 08:15 PM
evo unknown's Avatar
mobil 1 10w30, you should just replace it a little more often.
Old Apr 7, 2009 | 08:18 PM
evowario's Avatar
amsoil dominator ftmfw best s hit out there.
Old Apr 8, 2009 | 05:37 AM
gsrboi80's Avatar
Still on the stock bottom end 111k Mobil 1 10w-30 it's whole life.
Old Apr 8, 2009 | 06:22 AM
recompile's Avatar
There's nothing wrong with using a 0w instead of a 5w or a 10w... especially in New England. The only "downside" is its more expensive.
And a 30 weight really isn't thick enough IMHO... a few winters ago I had 5w-30 in my car and I was stuck in traffic for 2 hours due to a blizzard... the oil started to break down and my oil pressure warning light was coming on due to overheating oil. Ever since then I will never use 30 weight again.
And 0w is much easier on the engine in cold starts, so if you're willing to spend a couple bucks more, go for the 0w-40.
Old Apr 8, 2009 | 06:24 AM
recompile's Avatar
The OP also asked about what oil for a built motor... When you build a motor it typically has wider clearances than the stock block, which calls for a thicker oil. He could probably use up to a 50 weight without issues, but a 40 weight is perfectly fine
Old Apr 8, 2009 | 01:56 PM
cij911's Avatar
Excellent catch (I am afraid I missed that...)...
To the OP -- You may want to contact your builder to determine what weight oil he/she recommends....I agree with Recompile that most built motors would do fine on a 40 or 50....
