Boost leak problem!!
Old Apr 15, 2009 | 07:56 PM
grex_rs's Avatar
Well i have a boost leak some wheres but i dont know where, i checked every single connection and every thing is secure, i'm running 21 lbs on my tme 20g and theres no problem until i get around 6k rpms, from 6k to red line the boost drops to 16 lbs....so if some body is having this problem please help me!
Old Apr 15, 2009 | 07:59 PM
N3VO's Avatar
use soapy water on the usual areas clamps and hoses on licp uicp i woudl check, it will make it alot eaiser to tell
Old Apr 15, 2009 | 08:01 PM
Macaroni's Avatar
Boost leak test.
Old Apr 15, 2009 | 08:02 PM
danameisoj's Avatar
make a tester and charge the system up to check for leaks.
i just did it yesterday and found a 1 inch gash in a coupler. fixed it and the car pulls like a champ!
Old Apr 15, 2009 | 08:10 PM
N3VO's Avatar
oh i read this post wrong i thought you said you already boos leak tested it and couldnt find the leak my bad well yes make a tester and if you cant find the exact area put soapy water on where you think it is an that should reveal it
Old Apr 15, 2009 | 08:15 PM
grex_rs's Avatar
I will try that tomorrow, i was asking some friends from here and they ware telling me that it could be my wastegate but i have an upgraded one with a 17 lbs spring, what do you guys think?
Old Apr 15, 2009 | 08:17 PM
Macaroni's Avatar
I have the 18 lb. spring in mine and even if you were just running on wastegate, you would be holding 17lbs. It sounds like a boost leak. I would put money on it.
Old Apr 15, 2009 | 08:18 PM
sikwititevo9's Avatar
is your car tuned? or do you have a boost controller?
Old Apr 15, 2009 | 08:21 PM
grex_rs's Avatar
No i havent ....the only thing i checked was that all the couplings were in and tight and from what i can tell every thing looks fine but until i get the test done i will know.
Old Apr 15, 2009 | 08:23 PM
grex_rs's Avatar
Yes the car is tune and im using a hallman bc
Old Apr 15, 2009 | 08:30 PM
did it start happening after they tuned it? need some more info?
Old Apr 15, 2009 | 08:40 PM
grex_rs's Avatar
No that started when i change the turbo, well at least thats when i first notice the problem...
Old Apr 15, 2009 | 08:42 PM
grex_rs's Avatar
Originally Posted by evogirl916
if you dont have cams, power falling off after 6k is normal. 16 psi on a upgraded turbo is not.
I do have cams gsc 272 264 so i dont think thats the problem, thats why im here,lol
Old Apr 15, 2009 | 08:49 PM
check all the clamps, vacuum hoses, intake pipe, blow off valve, intercooler, piping, maybe an exhaust leak at the manifold or turbo gasket in between the turbo and manifold i can almost gaurantee its a vacuum leak
Old Apr 15, 2009 | 08:55 PM
grex_rs's Avatar
I will try that tomorrow but if no luck keep posting more ideas....
