Best cams for stock 9 Turbo??
You can do the Kelford 272's or GSC S2's while staying with the stock valvetrain as long as you don't go beyond the stock rev limit. At least that is what I have gathered.
Any tuners wish to comment??? Maybe GSC?? Or the like????
I am on a stock 9 turbo and had bc272's in the car. There was minimal gain, and they were a pain in the butt to get dialed in. I am switching over to FP4r's, one because they are local and 2 there are a couple of locals who have had great gains with them on the stock turbo. Also, they don't break..and two of the worst cam breaks are local to me (Booster9 and TNT)
Sup Jason. The M2s are nice cams, but the FP4Rs are a bit more agressive & can be run on stock valve train. Keep in mind I swapped the M2s out of that stroker for my FP4Rs without a second thought. I love em & would recomend then to anyone. FWIW my car made 350hp on the Dyno4mance DD which is the most they have seen out of similar setups. Most stock turbo bolt on cammed cars are arround 330 there.
I don't know much about the S2s, but when I pulled the M2s out I did an eyeball comparison of them to the FP4Rs & they have a much shorter duration. I hear great things about the Kelford 272s also. Those were the other cams I concidered, but I ended up choosing the FP4Rs & couldn't be happier. I'd offer you a ride along, but by the time it's running again it wont be a fair comparison.
You can still have a ride though.
the iddle, driveability is a little off from the stock cam but again is a 272 cam is very aggresive you should expect that from a big cam.
plus the way i look at it is iam ready for when i decide to go bigger turbo.
i have been tols many many times, do not be affraid of big cams, my take is when it comes to cams dont be affraid and put big cams i there
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Its true, my car did not pick up a whole lot of power with cams on a good running stock turbo setup. Maybe 15hp. If I was going for a simple daily driver I would spend my money elsewhere until he upgrades turbos.
Stock 9 turbo and cams will make 400hp+ I trapped over 120 on stock cams.
Fathouse
Fathouse
I agree with DBallz.... people with aftermarket cams on the stock turbo aren't trapping any higher than people with stock cams.
During my tuning session I noticed that the MIVEC map can make a huge difference in power even on the stock cams. I think that's why some people believe they've picked up power after a retune.
I'm now at 118mph on 100 octane stock turbo / stock cams at 26 psi.
