NGK BPR7ES Spark plugs (Discontinued ?????)
Old Apr 27, 2009 | 09:03 AM
Evokid03's Avatar
well when i went to advance auto parts and murrys auto they both told me that 2023 part number has been discontinued
Originally Posted by fugiwara
I am boosting 23psi in 3rd gear. I just bought set of bpr7es from NAPA last week, stock number is still the same 2023, my guy works there never told me anything about bpr7es being discontinued or change part number.
I ran br7es last week and I had serious missfire issue, fuel are not being burned completely. br7es are shorter than the bpr series and NGK never recommends br series for evo, and I notice poor MPG when I run br7es. when I put bpr7es and br7es side by side, br7es is shorter than bpr7es, I am guessing br7es is shorter therefore it doesn't reach far enough to burn the fuel.
After I switch back to bpr7es, miss fire was completely gone, will never go back to br7es.
I am debating to run bpr8es or not since my evo is not stock and has cams.
Old Apr 27, 2009 | 09:04 AM
skatermsmn's Avatar
anyone switch from bpr7es to bpr8es please share your experience....
I made the switch for a little bit and the went back to the bpr7es, Now I wish I would have stayed with the bpr8es. Im having a little trouble with my ignition in the upper rpms with the bpr7es's
Old Apr 27, 2009 | 09:50 AM
dancarroll0283's Avatar
I switched to the 8's after I put on intake and exhaust
Old Apr 28, 2009 | 04:14 PM
31underpressure's Avatar
I agree. I would go with the colder heat range unless your plugs starts to foul out.
I am using the colder heat range (ER12S) on my EVO 9 as Briskracing recommended and I am very pleased with them. They say running too hot of plugs in a modified car may damage the spark plug and/or engine.
I am not sure what heat range Brisk plug my buddy runs in his EVO 8 but I will try to ask him when I get a chance. Now I would kind of like to know myself
Old Apr 28, 2009 | 04:32 PM
evo8fl's Avatar
they told the same thing, so I when to another store and they still have some I bought 8
I run bpr7es with no problems at all @ 34psi, used to run bpr8es and did have misfire all the time
Old May 4, 2009 | 11:43 AM
wickdaddy's Avatar
yep had the same thing here in NE Ohio..
I went into the Murray's Discount Auto where I usually get my BRP7ES plugs locally and they told me that they are no longer going to carry them because they are discontinued.
In disbelief, I went to NAPA and got the same story.
I did end up finding a vendor online that still has them cheaper shipped than what I found them locally..
Here's the link to the BPR7ES
Click Part Number Search and drop 2023 or BPR7ES in the search
Just picked up 30 for $54.27 shipped and already have them in hand
I'm going to have to go in there and see if they have them by the new 5534 p/n
Old May 6, 2009 | 07:58 PM
cornercarver's Avatar
No need for 1 step colder unless you are going bigger power, 400+.
Old May 6, 2009 | 08:08 PM
Evokid03's Avatar
New spark plug number for the bpr7es is 5534
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
polish_pounder
17
Jan 30, 2011 10:24 AM
tribe
Jan 4, 2011 05:30 PM
Gary@MellonRacing
Sep 24, 2008 07:00 AM
jusa4cyl
19
May 20, 2007 02:34 PM
