Dead clutch pedal!!!!
Old Aug 12, 2014 | 01:52 PM
JDMEVOLEX's Avatar
Having the same problem right now ! was driving on the highway and suddlenly the clutch went straight to the floor. I could touch it with my pinky and itll drop right away. I didnt see any leaks or nothing like that and it still has fluid. Had to power shift all the way home =/
I bought another slave cylinder, but a local friend that has an evo said that it might be the pin inside the tranny that popped out. How can i clarify that and also when i have the car running it and i try to move the fork to engage the gears i hear a grinding noise, sounds like it slipped off the fly wheel. I need some help my evo brothers !
Old Aug 12, 2014 | 02:03 PM
SilverShadow03's Avatar
Wedge collar & ring could have popped off/bent.... IF you have a pull style clutch, the ACT Monoloc would be the way I would go.
Old Aug 12, 2014 | 04:37 PM
Ryan.Kauz's Avatar
^monolock looks pretty good!
I'm having a problem where the clutch pedal comes up, but is about 2" short of it's maximum height.
There is an tiny leak from the master cylinder against the firewall as the black paint has been stripped from the canister directly under the cylinder, but that doesn't seem to leak enough to have caused the problem.
jamaicaboost
Dec 17, 2016 09:46 AM
nor11384
Nov 26, 2016 08:05 AM
jplgsx
Nov 18, 2008 06:32 PM
R0ME0
Apr 4, 2008 07:32 AM
woobos
Sep 29, 2003 11:29 PM
