2004 Non-ACD, Front LSD
Old Apr 30, 2009 | 04:02 AM
MitsuJDM's Avatar
I'm looking at buying a 2004 Evo. It does NOT have ACD, so it has a 9.8 turbine housing right? Also, more importantly, I tried searching, but only found RS info. The non-ACD 2004's do NOT have a front LSD, correct? I know there are the later 2004's with ACD and the 10.5 housing, but if I remember correctly, they still didn't have front LSD.
I already have AMSoil MTG GL-4 on order and was wondering if I'd be able to use it in a 2004 Evo. Thanks
Old Apr 30, 2009 | 04:10 AM
meckert's Avatar
you got it
Old Apr 30, 2009 | 04:15 AM
sparky's Avatar
Originally Posted by MitsuJDM
I'm looking at buying a 2004 Evo. It does NOT have ACD, so it has a 9.8 turbine housing right?.....
I was not aware of this distinction. I thought that all 2004 Evos came with the 10.5 cm turbine housing(At least the USDM ones did, I think?).
Old Apr 30, 2009 | 04:18 AM
Copenhagen's Avatar
'05 was the first year for the 10.5 housing.
Old Apr 30, 2009 | 04:34 AM
MitsuJDM's Avatar
Alright. I was more concerned about the LSD. So I'll be able to use my GL-4 MTG I got? That's good. The 10.5 housing question was an after thought as I was making the post
This is if I decide to buy the Evo anyway :-/ I might not be able to afford another Evo
Old May 22, 2009 | 11:39 AM
MitsuJDM's Avatar
So a 2005 Evo, with ACD has a facotry front LSD, which I wouldn't be able to use a GL-4 trans fluid. I'd need GL-5? Or is the LSD only available in the IX's and VIII RS's?
Old May 22, 2009 | 12:55 PM
mt057's Avatar
The 04 only has the lsd in front on the rs. I believe that all 05 had an acd and a lsd.
Old Jun 17, 2009 | 03:50 PM
VGergo's Avatar
Hello
In the Evo 8 non ayc non acd open front differential can I put the Evo 8 MR helical lsd or the Evo 9 ?
like this one : http://cgi.ebay.com/ebaymotors/JDM-E...205|240%3A1318
The rear : in the evo 8 usdm non ayc rear differential house can I put the Evo 9 RS inside ?
Thank You ! Gergo
Old Jun 17, 2009 | 05:25 PM
Kracka's Avatar
All Evo 5-speeds use the same GL-4 transmission fluid and GL-5 transer case/rear differential fluid; same as whats used in DSM's too.
doncarbone
11
Sep 15, 2014 03:39 PM
angus4130
Aug 16, 2014 07:22 AM
An04EVO
Mar 4, 2011 09:42 PM
SeeCoryRun
Apr 5, 2010 09:54 AM
pepe le pew
Jan 10, 2008 11:01 AM
