New O2 sensor, now won't Start HELP!!!
Old May 3, 2009 | 02:48 PM
minimkiv's Avatar
I installed a new Bosch O2 sensor (15733) using the following· EVO - Bosch· Blue - Black· White - Grey· Black(2) - White (2) Now the car will not start, turns over but no start. Tried to read the codes using an OBDII and kept getting a “Fail” message. Did I some how screw up the ECU? This is my nephews car and I really hope I did mot mess it up. Note:Reattached the old sensor and still will not start
Old May 3, 2009 | 02:53 PM
reyrey's Avatar
have you tried re-setting the ecu?
Old May 3, 2009 | 02:57 PM
minimkiv's Avatar
How do I do that?
Old May 3, 2009 | 03:15 PM
reyrey's Avatar
just un plug the battery. leave disconnected for a couple of seconds. 10-30 maybe.
Old May 3, 2009 | 03:34 PM
minimkiv's Avatar
Left it unconnected for 10-15 min's, no change. Additional info: I pulled the spark plug wire from the coil and did not get a spark when I jumped the coil to ground when cranking the engine.
Old May 3, 2009 | 03:38 PM
sikrsix's Avatar
Sounds like you fried the ecu. You can unplug the 02 sensor, have a bad one and it will start. It will throw a code, but it will run.
Old May 3, 2009 | 03:41 PM
reyrey's Avatar
i'd have to agree. ecu fried my friend.
Old May 3, 2009 | 03:42 PM
reyrey's Avatar
you should be able to find one on here tho. gl!
Old May 3, 2009 | 03:55 PM
Kracka's Avatar
Did you disconnect the negative battery terminal before doing any work?
Old May 3, 2009 | 04:49 PM
joehoo's Avatar
lol ^^^^^ where do you some of you guys come up with this.....
man check some of your fuses. start under the hood and go from there. gl
Old May 3, 2009 | 05:50 PM
minimkiv's Avatar
I'm praying it's not the ECU, and no I did not disco the battery but was VERY carefull to be sure no wires crossed. I'll check fuses tomorrow, any idea of which ones to look at?
Old May 3, 2009 | 06:00 PM
dan l's Avatar
rtfm
Old May 3, 2009 | 06:04 PM
Import Junky's Avatar
not sure myself....hope you get it worked out.
Old May 3, 2009 | 06:19 PM
vicksen's Avatar
Definitely check your fuses. I'm not sure how you could fry an ecu by changing the o2 sensor, maybe if you attempted to attach a tazer to the o2 harness. You didn't did you? Didn't think so. Your engine bay fuse box will have a diagram on the inside of the lid, check every fuse that has a picture of an engine corresponding to it's position. After that check the rest for good measure.
Old May 3, 2009 | 06:22 PM
dan l's Avatar
Originally Posted by vicksen
I'm not sure how you could fry an ecu by changing the o2 sensor, .
The O2 sensor has 12 power, ground, shield, and signal. Do the math......
