need help,can't boost past 14 psi
Old May 4, 2009 | 09:58 AM
sparky's Avatar
So, try this: Run a length of hose directly from the turbo`s compressor housing discharge nipple to the WGA nipple. Adjust boost by rotating the turnbuckle on the threaded end of the adjustable length actuator rod. Rotate the turnbuckle in, clockwise, which effectively shortens the overall length of the actuator rod and increases WG spring pressure. Try about three coplete 360* rotations to start with.
Old May 11, 2009 | 11:55 PM
kpr's Avatar
kpr
Wait....you have only 14.8 psi boost...when you let off the gas RPM drop to 200...your mechanic told you the rpm drop was normal? Find a new mechanic ! Wastegate boost is around 11 psi +/- a couple psi. This sound like a simple vacuum leak. Keep in mind it does not have to be on the wastgate or turbo to effect this, you have to check all vacuum lines.
wazmunstr
Jun 28, 2014 05:54 AM
evo854880
14
Sep 13, 2013 10:22 PM
talontsi97
Jul 18, 2012 12:43 PM
LivinloudEvo
Jan 31, 2011 03:43 PM
crf inc.
Lancer Aftermarket Forced Induction Tech
43
Jun 5, 2010 02:19 PM
