Help! DRAINING coolant
Old May 8, 2009 | 07:55 PM
etuhs's Avatar
What the heck is going on?? I just bought a new radiator and now everytime I drive, the car literally DRAINS the coolant and I cant find exactly where its coming from... I had the aftermarket radiator cap on, but changed today to the stock cap. Here are the pictures I took from what I found:
Attached Thumbnails Help! DRAINING coolant-evo001.jpg   Help! DRAINING coolant-evo003.jpg   Help! DRAINING coolant-evo004.jpg   Help! DRAINING coolant-evo008.jpg   Help! DRAINING coolant-evo014.jpg
Old May 8, 2009 | 07:59 PM
ak47po's Avatar
Water pump.
Old May 8, 2009 | 08:01 PM
etuhs's Avatar
That was fast... and thats what i figured, so I already bought one. thanks man
bbyevo8u's Avatar
when you drained out your coolant did you drain from the block & radiator??
bbyevo8u's Avatar
why would it be the water pump?
Old May 8, 2009 | 08:03 PM
etuhs's Avatar
Yeah.. everything was drained when it was changed
Old May 8, 2009 | 08:12 PM
badhabit90's Avatar
+1/\ water pump has a weep hole and once the bearing fails or seal fails, it will drain from said spot. pull the timing cover off the top and look down between the cam gears. you will see the pump. if the timing belt is wet...stop driving it if you can before you slip the timing belt and slap all the valves and have a bigger problem.....
Old May 8, 2009 | 09:09 PM
etuhs's Avatar
Thanks dude. I appreciate all the help
Old May 9, 2009 | 08:24 PM
badhabit90's Avatar
did you pull the cover off and have a look??
Old May 9, 2009 | 08:31 PM
Kracka's Avatar
The added pressure from the aftermarket cap was probably the final straw and caused the pump to start leaking.
Old May 9, 2009 | 08:33 PM
shivaswrath's Avatar
Wp
Old May 10, 2009 | 09:49 AM
etuhs's Avatar
Yep, no doubt about it. Definitely the water pump.
Old Feb 28, 2020 | 12:14 AM
bean3452's Avatar
coolant leak
I have a 03 Mitsubishi lancer oz rally that has a coolant leak behind one of the pulleys and I don't know what it is any ideas
Evoryder
Apr 29, 2019 10:09 AM
Mark Hubley
Lancer How Tos / Installations
20
Jun 3, 2018 02:26 PM
EvoCop
Evo X How Tos / Installations
14
Jul 11, 2015 11:09 AM
56Hotrod
Jun 26, 2007 06:09 PM
lbcevo
Oct 5, 2006 08:40 PM
