The thing that the crank sensor uses. Its a thin sheet metal. I dont know how else to describe it lol. Recently my crankshaft sensor went bad and I think its because that metal thing is bent somehow. If you guys could tell me the name and the part number please. Also a picture of one would help so I can compare to mine.
Quote:
Crankshaft angle sensing blade?Originally Posted by def1
I think the reason Mitsu went to a pull type clutch is to keep that metal thing from getting bent. You may want to check for crankwalk.
Quote:
It was to prevent crankwalk.Originally Posted by barneyb
The metal is the crank trigger plate.
Tags
called, crankshaft, el, metal, metalthing, paso, piece, pulley, whats
