E3 Spark Plugs
Old May 14, 2009 | 09:00 PM
brandonseydel's Avatar
E3 Spark Plugs
Just put these in after backfiring under load.....fixed the issue and work great!! I used to run ngk bpr7eix but these feel much better .....the results are superb def try these out your next oil change
Old May 14, 2009 | 09:01 PM
idriveanevo's Avatar
whats the part number? why didnt you try to run the coppers?
Old May 14, 2009 | 09:02 PM
jxs1984's Avatar
where u get them
Old May 14, 2009 | 09:14 PM
KenMasters's Avatar
Do a search in theese forums on that plug. I'm pretty sure that people were having issues with them failing and causing engine damage. It's worth a search.
Old May 14, 2009 | 09:22 PM
Fast_Freddie's Avatar
Veteran: Navy
I won't even run those in my lawnmower...
Old May 14, 2009 | 09:28 PM
KenMasters's Avatar
After what I read and saw on theese plugs, neither would I.
Old May 14, 2009 | 09:35 PM
Veteran: Navy
Your backfire under load was due to having old *** fouled plugs... BPR7EIX or BPR7ES gapped at .024 would have solved your problem instead of using "snake oil" spark plugs...
Zodiac13's Avatar
^ +1
Old May 14, 2009 | 11:32 PM
Spoolin4g63's Avatar
why would you run these plugs, look at the design your just asking for trouble
Old May 14, 2009 | 11:38 PM
MitsuOZ's Avatar
+1 for the $40 downgrade
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
