Tranny Oil Options?
Tranny Oil Options?
Hello..
I need to fill up my tranny and tc so I can get the car running again
It is ok to fill the tranny with Motul Motylgear 75W-90??it says api gl4,gl5
Mobil? something called Venoco Oils ,texaco Havoline?
Also What oil I should use on the TC ? I know that You reccomend diaqueen or amsoil but I dont find amsoil or diaqueen here in my country..
LMK what should I use thanks
You want a GL4 for the transmission, not one of the universal GL4/5. Try Redline MT-90(2)/MTL(1) in the transmission and Redline 75W-90 GL-5 in the transfer case and rear differential.
http://www.maperformance.com/redline...d-dsm-evo.html
I have personally used Motul, "Gear 300", 75W-90, in my 5-spd., JDM RS tranny for about 78,000 Km. So, I would recommend using the Gear 300 instead of the, MotylGear, that you mentioned. Although, if you can't get the Gear 300, then I wouldn't hesitate to try the MotylGear.
Also, I use, Motul Competition ff, gear oil, in both the rear diff., and the transfer case. Here in my country, the more widely used gear oils that are sold in the U.S., such as Redline, DiaQueen, or Amsoil, etc., are just not available.
diaqueen is a Mitsubishi fluid. You can buy a liter at the dealership. You may be able to have it shipped? It is expensive stuff but your transfer case will thank you. As far as your tranny good luck. I couldnt imagine not being able to have something locally shipped.
