Car Stalls When Started
Old May 18, 2009 | 10:34 PM
Blayq Owns You's Avatar
Hey all, I just got my Evo VIII the other day and haven't had any issues until today.
All of a sudden, when I started the car, it was idling at ~500 RPM and was about to stall, it would jump to 1k, drop to 500, and repeat. Now, after letting it sit, it starts, goes to 1200 RPM, and just drops to 0 and stalls.
I don't know much about the car itself but it isn't modded much at all (catback, bov, air filter). Anyone have a solution? Thanks in advance!
Old May 18, 2009 | 10:39 PM
NsinEvo8's Avatar
check o2 sensors, ic pipes, & bov
Old May 18, 2009 | 10:50 PM
chaotichoax's Avatar
replace the bov with a stock unit to start
Old May 18, 2009 | 10:53 PM
Swft Evo's Avatar
vacuum leak? i had one once and the rpms jump up and down
Old May 18, 2009 | 10:55 PM
shomesomesho's Avatar
Im the Op's friend and I'm working on his car. The IC pipes all seem fine. What should I be checking with the BOV? He has a SSQV in VTA. Nothing looks out of place.
It was running fine before the heavy rains this evening. It doesn't seem to have taken in any water since it starts, revs and then slowly loses its rpm. If you give it gas and hold it steady, it gradually loses rpm. Any help is greatly appreciated
Edit:
Where should I start? I have an Evo X but I've never worked on the VIII's
Also, the car has no codes.
Old May 18, 2009 | 11:03 PM
Evokid03's Avatar
hmmm, i would make a boost leak tester and test ur system.
Its not ur bov, my buddy has the same one.
Old May 18, 2009 | 11:26 PM
We disconnected the MAF sensor and the car isn't having any idling issues anymore. Apparently the water damaged it or something and we'll fix it or replace it tomorrow.
Thanks for the help guys
Old May 18, 2009 | 11:29 PM
Double post due to my failed internet. Sorry =X
Old May 19, 2009 | 10:34 AM
FX11's Avatar
+1
rich3389
Sep 8, 2024 07:27 AM
Fedetronchet
Dec 10, 2016 11:13 AM
supak111
Mar 28, 2016 03:25 PM
brandon oz
Dec 13, 2012 04:15 AM
Rands
Dec 4, 2009 07:44 AM
