IC Sprayer not working
Old Oct 2, 2003 | 06:05 PM
EVOPILOT214's Avatar
Angry IC Sprayer not working
I only used my sprayer for the first couple of weeks I had my EVO, ensuring that it was full...I stopped using it for a couple of months then noticed it wasnt working. When I check the resevoir it was empty so I filled it back up and still not joy. Sorry if this has been posted before but I came up empty with my search. Anyway I can fix this without having to go to the dealership.
Old Oct 2, 2003 | 07:37 PM
kidnice's Avatar
Did you ever have to take off your center console? Maybe the harness is loose
Old Oct 2, 2003 | 07:42 PM
mojo's Avatar
In the manual it says you can burn up the pump or something to that effect if you use it without water in the resevior. I know you said you weren't using it but maybe you could have hit auto by accident when it was empty. Just take it to the dealer. Then again they'll probably tell you its the rusult of your mods and refuse to fix it .
Old Oct 2, 2003 | 08:00 PM
I had an alarm installed...maybe for some reason they loosened the harness by accident...and the only mod I have is a grounding kit...knowing mitsu they will prob. try to say that was the cause...
Old Oct 2, 2003 | 09:59 PM
kidnice's Avatar
Thats what happened to me. My alarm installer had to take off the center console and when he placed it back on he forgot to plug the ic harness back in. The center console is easy to remove, so you will be able to check and see if thats the problem easily.
Old Oct 2, 2003 | 10:15 PM
Thanks ...ill give a try
Old Oct 2, 2003 | 10:22 PM
Hey kid you were right..they forgot to plug the harness back in...hard to find good help these days...now I just have to worry about the grinding in fifth at high rpms...thanks a mil dude
jagarcia89
Oct 4, 2014 08:42 AM
lancer586
Lancer Troubleshooting
Jan 27, 2012 01:05 PM
lancer586
Jan 29, 2011 12:13 PM
4-BNGR
Jul 25, 2006 01:12 PM
RalliArtEvoVIII
Mar 5, 2005 08:44 PM
