Windshield sprayer help!
Old Jan 20, 2012 | 11:40 AM
lancer586's Avatar
Help my windshield sprayer has stopped working, is there a fuse for it or how do i fix the issue. I dont hear a noise from it when i press the sprayer like water trying to come out.. maybe somethings broken?
Old Jan 20, 2012 | 03:40 PM
CrAnSwIcK's Avatar
did you fiddle with the hoses at all? swap your hood etc?
if not it's a fuse or the pump is dead...easy fix. you don't even need to jack the car up if you're on stock suspension to change the pump...though it is easier if you can lift it up a bit...
check fuses 2, 3 and 5 in the panel unde rthe steering wheel...and fuses 7 and 22 in the relay/fuse box under the hood. if all are good buy part MB286961 from mitsubishiparts.net, or pay double at the dealer, at least that's the case here in Canada..
Old Jan 21, 2012 | 12:42 PM
slatermvp's Avatar
check the house on the passenger side as well. There is a little hose that goes from the reservoir to the hood. My hose came loose and rubbed on the tire. I have to go to the junkyard and take one out of a mirage or something.
Old Jan 21, 2012 | 01:10 PM
CrAnSwIcK's Avatar
he can't hear the pump...it should be quite audible from the cabin...
Old Jan 27, 2012 | 12:28 PM
Tapsta's Avatar
should be under warranty. i say go to the dealer is you haven't fixed it by now.
Old Jan 27, 2012 | 01:05 PM
03lances's Avatar
I doubt a 2003 lancer will still have the washer motor under warranty. As Cranswick already suggested if those fuses are fine I would take a simple multimeter and test for power at the plug for the motor. If you have power then the motor is toast and need another. If you dont then you have a short somewhere in the harness.
mossontree
Mar 3, 2018 04:40 AM
C0dyix
Mar 18, 2017 05:41 AM
fuzzycuffs
Dec 11, 2016 09:32 PM
Meez
May 14, 2016 06:18 AM
llDemonll
11
Nov 23, 2011 06:47 PM
