Turbo Oil Feed/drain lines
Old Jun 1, 2009 | 11:54 AM
03whitegsr's Avatar
I've got a custom exhaust manifold for an EVO IX turbo that has moved the position of the turbo slightly. The stock oil lines won't work so I need an aftermarket drain line with a little more length. The stock feed line would probably work, but I'd rather just replace it with a flexible line.
Does anybody offer a replacement oil feed and drain line that will work with the stock turbo?
Old Jun 1, 2009 | 11:59 AM
SRT-TO-EVO's Avatar
Fp.
Old Jun 1, 2009 | 12:19 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by SRT-TO-EVO
Fp.
Old Jun 1, 2009 | 12:20 PM
03whitegsr's Avatar
Been trying to get a hold of them for days now.
Anywhere else?
Old Jun 1, 2009 | 12:29 PM
SRT-TO-EVO's Avatar
Anywhere else?
Not that I know of. Did you try calling them? That's how I always got in touch.
Old Jun 1, 2009 | 12:40 PM
03whitegsr's Avatar
Yep
Calls, Emails, voice messages, tried it all
I normally can get somebody there, but I have zero luck for the last week and need to get the parts to get the car back together.
Old Jun 1, 2009 | 02:22 PM
CO_VR4's Avatar
PM me your phone number.
Old Jun 2, 2009 | 07:44 AM
03whitegsr's Avatar
Thanks, got the FP lines on the way.
Old Jun 2, 2009 | 08:54 AM
crcain's Avatar
One thing I didn't understand about the FP lines is they are way longer than need be and also my buddy is on his 2nd and they seem prone to leaking. Why FP wouldn't make the lines the right length is odd.
Old Jun 2, 2009 | 09:02 AM
03whitegsr's Avatar
The feed line or the return?
The feed line needs to be long so that it can wrap around the front of the turbo. If you try to run it behind the turbo like the stock routing, you'll find the teflon lining melts and then leaks.
Old Jun 2, 2009 | 10:41 AM
crcain's Avatar
Yep was talking about the feed line. Thanks for the info I'll have to see how my friend has his clocked off the turbo. Your explanation might be the answer to why he has so much slack.
BrownSuga
Sep 28, 2016 03:56 PM
Biggy VIII
Aug 9, 2016 03:06 PM
EVO10190
Aug 12, 2015 03:49 PM
Anarchy99
Apr 30, 2013 08:00 AM
diablo1
Jul 14, 2011 08:46 PM
