BBK Advice
Old Jun 4, 2009 | 05:34 PM
lan_evo_mr9's Avatar
BBK Advice
As the title states, I'm wondering which version to get. My car is set up for autocrossing and only autocrossing. I don't care about being the fastest on the highway or anything like that. I'm pretty happy with my current setup but want a little more. I want one of the BBK's, not the green, red or tomei. I have my own reasons for that, so please don't suggest any of the others. I'm looking for input from people with experience with both versions. I'm interested in spool first off, mid range second, and top end third- although, I don't want a car that falls flat after 5.5 or 6K. If there are any other auto crossers out there that want to put in some input on other turbos- please tell me why you made that choice. Mind you, I'm on street tires and I'm already able to spin all 4 in second at full throttle. Thank you for your time and input.
Old Jun 4, 2009 | 05:41 PM
hks-evo's Avatar
full thats all i got to say
Old Jun 4, 2009 | 07:26 PM
What's the spool RPM on the full? Stockish? I'm leaning towards the full, but I was wondering if anyone has had experience with the lite version.
Old Jun 4, 2009 | 07:27 PM
localtoys73's Avatar
u need to PM kemist he has the lite and loves it i havent had a chance to ride in his car but i hear its a blast
Old Jun 4, 2009 | 07:35 PM
chaotichoax's Avatar
there is a whole thread dedicated to the bbk turbos and their results...post there
https://www.evolutionm.net/forums/se...ts-thread.html
or pm chad and see what he has to say
Old Jun 4, 2009 | 08:59 PM
red03evo's Avatar
+1 on this ^
I would pm chad and call the shop to see what he has to say.
He would point you in the right direction based on what you are looking for.
Good luck.
Old Jun 5, 2009 | 06:30 AM
scheides's Avatar
EvoM Moderator
I think the term 'spool' gets tossed around too much; I have the BBK Full and once you've eclipsed the boost threshold (the rpm at which the turbo will actually make boost quickly once you step on the gas), the BBK Full spools like a stock turbo. Step on it and it is there right now. Since you autoX, you may also be concerned with the actual boost threshold. On my VIII I'm seeing roughly 300-400rpm of lag over the stock turbo. I've also run the IX turbo on my VIII and it behaved very similar to the stock 10.5 VIII turbo. Specifically, I saw 25psi by 3400 on the VIII turbo and 3800rpm on the BBK Full.
I see you drive an IX, do you have cams yet? Cam selection on an IX can help improve boost threshold dramatically. I have some friends with FP4R's that see 25psi on their stock turbos by 3100rpms, so if they drive my VIII it feels 'laggy' to them since the boost threshold is higher. Once they've eclipsed the boost threshold, the complaints seem to quietly end
Anyways, the lite is a great option for autoX'ers too, since the boost threshold should be very similar to stock and you will see extra power up top. As far as holding power way up top, I cannot speak to the lite, but on my BBK full I have been nothing but impressed. On my alky/IX turbo setup I'd see peak power at 6200rpms and it would drop off pretty hard by 7500. BBK Full will hold 24psi flat from 3800-8000 on my pump gas tune and if I have the alky on 29psi tapering to ~24psi @8000 (on the street I've seen 26psi @ 8000). Power up top is there all the time, especially on high boost.
Anyways, CBRD is probably the best experience I've ever had buying something like this, I have been absolutely floored by their outstanding service and the product they've produced.
Here's my dyno results:
https://www.evolutionm.net/forums/ev...thy-motor.html
Here's my initial impressions:
https://www.evolutionm.net/forums/se...port-coat.html
Have fun with your purchase
Old Jun 11, 2009 | 08:54 AM
CBRD's Avatar
Shoot me a PM or email to cbrdspeedfactory.com
cheers
cb
thanks for the kind words everyone!
ilikeboost
17
Jul 11, 2014 11:04 PM
blackenedwings
22
Nov 4, 2011 11:58 AM
meggs00
47
Jul 17, 2011 10:09 AM
EVO8LTW
37
Sep 27, 2004 09:23 AM
LDB
Jan 21, 2004 04:04 PM
