Tune needed?
Old Jun 4, 2009 | 07:04 PM
evo unknown's Avatar
Tune needed?
Currently I have an Apexi TBE, and am looking into getting an ETS LICP. But I wanted to see if the licp would require a tune?
I have done my research and I believe the answer is yes, but wanted to see if that one part was ok to bolt on without one and do a tune at a later time when all intercooler pipes are changed.
Old Jun 4, 2009 | 07:09 PM
bluebanana23's Avatar
No, you only need tunes when installing parts that drastically change fuel or airflow. Such as fuel injectors, cams, or turbo.
Old Jun 4, 2009 | 07:12 PM
OK, I know stock tune is pretty rich, but the ETS licp would not effect the car to which it would not require a tune?
Old Jun 4, 2009 | 07:16 PM
LOVEBOOOST's Avatar
No sir you do not need a tune like the guy above us said only when ur changing something to do with ur air or fuel... Thats when u definitely need a tune
Old Jun 4, 2009 | 07:21 PM
Kracka's Avatar
You will not need a tune. A tune is a great, and often forgotten, mod though. The stock tune leaves a lot to be desired, especially mid-range.
Old Jun 4, 2009 | 07:47 PM
UICP would require a tune though, correct?
Old Jun 4, 2009 | 07:51 PM
LOVEBOOOST's Avatar
You dont need a tune for that from my understanding mods are really useless w/o a tune get most people get most of there mods on or ready to be installed then get a tune all at once a tune is really needed when u upgrade ur turbo, cams, injectors, intake, fuel pump, ect stuff that will change ur air/fuel ratio... If I am incorrect someone please chime in
Originally Posted by evo unknown
uicp would require a tune though, correct?
Old Jun 4, 2009 | 07:56 PM
DynoFlash's Avatar
if you currently have a reflash tune, then adding a lower fmic is not going to have a significant effect on the VE to require a retune. However, if you don't have a tune on the car, certainly in order to realize optimal performance a tune is suggested.
Al
Old Jun 4, 2009 | 07:58 PM
DynoFlash's Avatar
I agree, the best route is to plan your upgrade path and develp a goal on mind and try to do the modification steps in major groups so that you can minimize the number of times the car needs to be tuned and dyno time. Following - for example - a staged upgrade path - e.g. Stage 2 or Stage 4, etc is always a good way to start out as many of the stages build upon each other.
Al
Old Jun 4, 2009 | 08:00 PM
LOVEBOOOST's Avatar
Thanks Al, I knew ive done my research
Al
Old Jun 4, 2009 | 08:05 PM
Kracka's Avatar
Definitely not. They make far less difference than a LICP does.
Old Jun 5, 2009 | 12:03 AM
damie45's Avatar
I'm in the same boat. I want to get a LICP also. i already have a TBE, cone filter and a tune cause I was planning on stopping there, I guess u can't just stop with one Mod. Now my question is: will I make anymore power with the licp without the tune?
Sorry OP if I'm hijacking ur thread.
Old Jun 5, 2009 | 10:17 AM
Thanks for the input!!
What bolt on mods would require a tune then?
Old Jun 5, 2009 | 10:47 AM
GinNBoost's Avatar
Exhaust, intake, boost controller
cyu06
Apr 7, 2014 09:51 AM
benIX
27
Feb 26, 2014 11:16 AM
shLa11
Nov 2, 2012 09:58 PM
thedru13
May 17, 2010 04:12 PM
bmincey
15
Oct 16, 2008 12:17 AM
