lost boost
Old Jun 4, 2009 | 07:13 PM
fenriq007's Avatar
lost boost
So i noticed the other day that i was only boosting 19lbs tapering down to 15lbs , i'm tuned for 22-23 tapering down to 19-18. What may be the cause of this. I turned up the boost on my MBC and it's holding normal againg 22lbs tapering down to 18-19 lbs. Could it be the weather getting warmer? a boost leak? Any help would be appreciated
Old Jun 4, 2009 | 07:18 PM
Kracka's Avatar
It could be the weather, it could be a boost leak, or it could be both. In warmer weather you'll get less boost if you set it when colder. Its never a bad idea to test for a boost leak though!
Old Jun 4, 2009 | 07:35 PM
evokid511's Avatar
the wheater could def be affecting it... as it gets hotter your not gonna be able to boost as much
Old Jun 5, 2009 | 10:02 AM
lanevo005's Avatar
I would do a pressure test on it to see if there is a leak.
Old Jun 5, 2009 | 01:30 PM
nonschlont's Avatar
^^^what they said... Temp. affects boost quite a bit... Always a good idea to check for leaks, but I would guess temp. change first... Did you have a big temp. change, getting hotter?
Old Jun 7, 2009 | 11:53 PM
LakerRaider's Avatar
so if it gets hotter and boost lowers about 1-2 psi, would it be safe to turn it up?
Old Jun 19, 2009 | 04:58 PM
toverton30's Avatar
check boost leak always
Old Jun 20, 2009 | 12:46 AM
sparky's Avatar
It's just the warmer weather, that's all.
