FPR Solenoid?!!!
Old Jun 9, 2009 | 08:03 AM
dxbevo9's Avatar
FPR Solenoid?!!!
hey guys...should i connect my after market fuel pressure regulator vacuum line to the nipple on the fuel pressure solenoid (located at the other end of the intake mani)??
thanks in advance
Old Jun 9, 2009 | 08:43 AM
Evo8Emperor's Avatar
just get rid of it and disable it through the periphery bits. less to look at. Along with that one get rid of the rest. lol. It looks much cleaner.
Old Jun 9, 2009 | 11:26 AM
dtuned's Avatar
It's just like isolating the stock boost solenoid when one goes to a MBC or to an elctronic BC. By the way... you did remove the stock fuel pressure regulator, right?
PS- did you get the too rich at idle problem sorted?
Old Jun 9, 2009 | 10:46 PM
dxbevo9's Avatar
yeah i removed the stock FPR and stock fuel rail..i am running an after market fpr and rail now.
i am still working on the idle problem...we think it is in the tune..because the car was tuned with a huge boost leak (in the intake manifold) in place..once the leak was fixed the car had excess fuel hence the rich condition..we are working on the tune now and hoping that this is the problem.
so you recommend i remove the fuel pressure solenoid?
btw..where are you guys connecting your Fuel Pressure vacuum line to...as well as the boost pressure vacuum line? i only find one bung on the intake manifold so i am forced to "T"-connected the fuel presure and boost vacuums to the intake mani.
thanks in advance
Old Jun 10, 2009 | 03:22 AM
I personally have extra vacuum sources all over the manifold because I took off all the solenoids.
Depending though the two vacuum ports on the TB one is post tb plate and the other is pre tb plate. So depending on what you need to tie in you have a choice.
The fpr I kept the vacuum lines coming from its original place just no solenoid now.
I also run a vacuum block to make things easy if I need more vacuum line spots. Between meth and stuff they fill up quick.
Old Jun 10, 2009 | 09:34 AM
dtuned's Avatar
A vacuum block. Those things are really handy and keeps clutter down to a minimum.
On the other thing... I am sure you guys will sort it out. GL!
Jovan Caro
Feb 6, 2017 08:03 PM
Evoguy!123
Jun 20, 2016 10:07 AM
Soda
Oct 3, 2015 04:50 PM
brandon1304
Jul 24, 2008 07:18 PM
firehawkta2000
AEM EMS
Apr 23, 2006 01:11 PM
