Engine Rebuild Advice
Old Jun 10, 2009 | 05:45 PM
Jackson Machine's Avatar
Originally Posted by crcain
Take a look at two of the top engineering minds on this board, TedB and jid2... both have built motors, both have gone through hell and back getting them working right. If the best of the best have problems, imagine an everyday joe?
At least one of them had a problem because they ran it with NO OIL! Find me an engine that will withstand that kind of abuse. Not much of a "guru", eh?
Old Jun 10, 2009 | 09:27 PM
crcain's Avatar
Whether someone checks their oil everyday is not qualification for guru status. Ted has helped people on this board with solid information for a long time and not because he is trying to sell motors.
My point was... that if you aren't gonna make a lot of power, a built motor is a flat out mistake. They are, when all is said and done, a friggen crap shoot.
Do you recommend built motors for the type of power the OP is making?
Now if you're gonna run 35+ psi on a Red or a T3 then that is another story.
Old Jun 10, 2009 | 11:57 PM
Tonba's Avatar
^ To be honest, there is only a handfull of 400hp stock block cars here.. anything over 350hp on pump (no e85) is generally built...
Old Jun 11, 2009 | 04:42 AM
20gmr's Avatar
Strokers are just as smooth as any 2.0 provided it's built correctly. The claims of them beating themselves apart are senseless.
Check out our website. We offer 2.0, 2.1 and 2.3 to suit any type of driving/racing. I'm sure that you'll find pricing to be comparable if not better than the ones you listed plus we have some specials going right now to sweeten the deal.
Your right, maybe beating themselves apart is the wrong way to word that, but isn't it "Fact" that the known greater rod angle of the 2.3 is going to wear things faster. I also didn't like the fact that some people were having to clearance the bottom of the bore with a 2.3 depending upon what rods they are running. I just don't see the point, I would much rather give up the slight gain in spool and just ring the **** out of it and make up fo rit on top end haha
I have seen several 2.3's with "resonance" problems as well, pegging the knock sensor at cruise.
I am not saying it can't be done right i just question weather its worth the hassle.
Old Jun 11, 2009 | 02:16 PM
Tonba's Avatar
Im pritty sure a high RPM 2.0L can wear out things fast too...
Old Jun 11, 2009 | 03:17 PM
ToMuchBoost's Avatar
I went with a built stroker for the fact that my car is a street car. I want the turbo i have hta 86 to spool up fast and make nice power on pump gas. If my car was going to be a track car mostly i would go with a 2.0L with a built head any day. You cant beat the extra rpm to be honest. I see your running a red though so the extra rpm wouldn't be needed but you could stay in the gear longer. For a track/1/4 car go with the 2.0L for a street animal go 2.3.
Old Jun 11, 2009 | 03:43 PM
Tonba's Avatar
^ Im not running a red
Also, I was asking for reccomendations on the stroker kit.
Whats peoples experience with the K1 crank? Is it worth the extra $850 over the OEM 100mm mitsu crank?
Old Jun 11, 2009 | 03:48 PM
sorry lol must of been another thread had a long day today . People are running 750+whp with the Oem mitsu crank. And since i doubt you will be going higher then that i would say no its not worth 850. Unless your going for alot more power.
Old Jun 11, 2009 | 03:51 PM
Tonba's Avatar
I thought it was lighter and better balanced?
Also, no one here is running that much power on a OEM 100mm crank..
Infact, one of the 600hp race cars here keeps snapping its 2.2L forged cosworth crank..
I think they are going to try something else..
Old Jun 11, 2009 | 04:09 PM
That's kinda odd because jam and other builders use the oem cranks. Look at jam's 850whp package it still uses the oem crank. I have a buschur 2.3 stroker and they use the oem cranks also. 600hp snapping a forged crank something isn't right there .
Old Jun 11, 2009 | 04:22 PM
Tonba's Avatar
^ The most powerful cars over here are no more then 400~450kw which is about 600~675whp. And thats on E85.
-600whp 2.0L running cosworth internals, T67 10CM + E85 (street car)
-670whp 2.4L running custom fully forged internals, custom GT35R turbo + E85 (time attack car)
-670whp 2.2L running cosworth internals, HKS 3037S + E85 (time attack car)
-750whp 2.4L running custom fully forged internals, custom GT35R turbo + E85 (Current world reccord holder for fastest evo 7sec pass)
These are the mose powerful cars we have over here in oz. The second last one has been through a few cranks now.. its been destroying forged cosworth cranks.. the car is built by a workshop that builds racecars, and LOTS of quick evos's.
Old Jun 11, 2009 | 07:04 PM
ny-quiL's Avatar
Originally Posted by andrewzaragoza
you could also check out buschur's stroker kit. i heard good things about it and based on their website its cheaper compared to ams https://secure.buschurracing.com/cat...4af2841a261a32
I think the original poster is over looking his best choice....
Old Jun 12, 2009 | 07:39 AM
GPTourer's Avatar
Maybe because the OEM Crank is better then all. Just because something is expensive and designed for racing doesn't mean its going to be better then an OEM piece that has been tested and retested and refined from over 20 years of development.
2.3stroker
Dec 3, 2014 08:45 AM
Phoenix*
13
Feb 20, 2011 11:37 AM
Tonba
Jun 14, 2009 05:54 PM
Tonba
51
Feb 25, 2009 01:57 PM
redlinedrift
44
Jul 14, 2008 01:53 PM
