when installing arp headstuds
Old Jun 10, 2009 | 11:14 PM
bbyevo8u's Avatar
i'm installing arp headstuds, should i replace the head gasket or do the 1x1 method?
can someone please give me some good advice, thanks
Old Jun 11, 2009 | 01:19 AM
house_of_senate's Avatar
Not trying to be the one to say search, but there really are ALOT of threads around on this. You will find your best advice there.
Old Jun 11, 2009 | 01:25 AM
EvoVIII808's Avatar
should replace gasket, but if not 1X1 will work. has worked for me, but there are alot of people here that it has not worked for. I installed mine myself, with no problem. Currently at 80k Miles , with 20k on the Arp's. good luck
Old Jun 11, 2009 | 05:53 AM
JakeTheVIII's Avatar
Might as well replace it now. The 1x1 works, but you are already in there...
Old Jun 11, 2009 | 06:03 AM
raasfaas's Avatar
The 1x1 method works and it doesn't take that much time really...as long as you follow the right "x" path you should be good.
Old Jun 11, 2009 | 06:08 AM
rawburt's Avatar
I've been using the 1x1 method for quite some time now with now. FWIW, I know there are a few big shops out there that are doing it this way.
Old Jun 11, 2009 | 07:23 AM
bbyevo8u's Avatar
start from the middle and work my way out right?
Old Jun 11, 2009 | 08:44 AM
raasfaas's Avatar
Old Jun 11, 2009 | 08:51 AM
Fast_Freddie's Avatar
Veteran: Navy
Until I actually lift the head with stock head fasteners I won't be bothering with head studs... JohnBradley has hit 500+ AWHP with the stock fasteners/stock block with no head lift... much can be attributed to the tune in this case as well...
Old Jun 11, 2009 | 09:00 AM
Steve93Talon's Avatar
Originally Posted by Fast_Freddie
Until I actually lift the head with stock head fasteners I sont be bothering with head studs... JohnBradley has hit 500+ AWHP with the stock fasteners with no head lift... much can be attributed to the tune in this case as well...
Exactly. Stock head bolts are underrated, standard ARPs are overrated. EVO guys are way behind the DSM world on this one, anyone at a power level where it's necessary to change to studs is using L19s or A1s to make it worth their while these days.
Old Jun 11, 2009 | 02:16 PM
bbyevo8u's Avatar
^^ well i have them so i'm going to put them in they got to be better then the stock one's.
just wanted to do it the right way the first time so i think i'm just gonna change out the head gasket!
Old Jun 11, 2009 | 02:18 PM
Veteran: Navy
Well sir I commend you for taking the head off to do these!
Old Jun 11, 2009 | 02:22 PM
Kracka's Avatar
There is a lot to be said for retaining the factory seal which is why I like to retain the stock head gasket and bolts for as long as possible. If you haven't blown your gasket, and the head isn't lifting, why bother doing the swap? IMO all you're doing is increasing your chance of failure.
Old Jun 11, 2009 | 02:27 PM
ev0lution9's Avatar
+1 on that for sure
Old Jun 11, 2009 | 02:29 PM
bbyevo8u's Avatar
i do plain on going with a red soon so i just want to be safe.
would it be bad to get tuned right after installing head gasket, do you have to break it in??
