Blox Front Motor Mount Install
Old Jun 13, 2009 | 07:23 PM
jvlazzar's Avatar
Every post about this mount claims a breeze of an install, but I can't for the life of me get the cross member bolts to line up...
when the 2 front bolts and mount are good, the rear bolt is 1/4 inch off. is there some sort of order of operations, or do i just need more leverage? the rear bolt is getting stripped as is...
thanks.
Old Jun 13, 2009 | 07:26 PM
Rushin's Avatar
Have you tried flipping the mount 180 degrees? That worked for me
Old Jun 13, 2009 | 07:32 PM
jvlazzar's Avatar
i thought about it, but the mount looks completely symmetrical. ill give it a try in the morning
Old Jun 13, 2009 | 07:46 PM
MR Turco's Avatar
no need to flip, it fits either way. use a screwdriver to line the mount hole up. The engine will settle once the cross member is out. This really is a breeze
Old Jun 13, 2009 | 08:16 PM
jvlazzar's Avatar
i had previously connected the mount first then tried lining up the bolts. you say connect the cross member and tie rods first, then worry about lining up the mount?
Old Jun 13, 2009 | 08:19 PM
evoIXcencal83's Avatar
i put mine in without even taking the crossmember out.
Old Jun 13, 2009 | 08:22 PM
Also if you look closely one hole is circular and the other is slightly elongated to allow for some adjustment.
Old Jun 14, 2009 | 04:41 AM
MR Turco's Avatar
If one hole is fixed how do you suspect you can adjust it? It is really for variance on the crossmember.
Old Jun 14, 2009 | 09:27 AM
turbolarry's Avatar
If you have to wiggle it use the tie bar; connect the bolt at one end and the center bolt. Just snug them up or finger tight. Use the other end for leverage and line things up.
Leave all the bolts on the cross member and motor mount loose so you can line things up and get the threads started. Once that's all good go back and tighten things to spec.
Old Jun 14, 2009 | 09:37 AM
jdowd's Avatar
i did what turbolarry did took about 5 min
Old Jun 14, 2009 | 11:22 AM
jvlazzar's Avatar
good call...connected the rear bolt first, forced the mount into position with a round file, everything else lined up.
Emmy
Nov 3, 2016 02:51 PM
gasolinebaptism
Apr 20, 2016 02:04 PM
blk-majik
Jul 20, 2015 08:18 AM
Huetsimus
Jul 5, 2015 04:19 AM
DangerousDan
Mar 21, 2006 12:34 PM
