how much boost taper is normal?
Old Jun 16, 2009 | 10:01 PM
TommiM's Avatar
I am fairly new to the evo scene. I recently installed a boost gauge and been reading on here about where oem boost readings are. I guess mitsu set the factory tune to have the boost taper a bit. Here is my question, I found an open road to test my car, in second gear 90% throttle I will boost to 20psi, then it tapers down to 15. 3rd gear at wot it stays at max 14 psi. Kind of weird but it also seems like its hitting a wall, not as responsive in 3rd as it was 2nd trying to accel from 5500 rpm on up,hmm... but in 3rd and 4th it just stays at 14 psi max. I was under the impression it should taper down to ~17 psi, so its quite a bit off. My car is a 2005 gsr, completely stock except for licp, evo 9 DV, and a perrin crank pulley (came with car when purchased). Also with new oem plugs gapped at .024". When I replaced my dv to the evo 9 metal one, I noticed my dv clamps were kind of loose. I want to go through and check all my clamps again, but I dont think that is the issue. I also am not sure if its my tb shaft seals, partly because I am able to boost to 20 psi, just wont hold past 14 psi. So any ideas that might help, thanks.
Old Jun 17, 2009 | 03:14 AM
sparky's Avatar
It's pretty easy to build a boost leak tester. Test it for leaks first.
Old Jun 17, 2009 | 04:00 AM
evoluvinevo's Avatar
thats right where ix turbos taper to. i know you have an 05 but they share the same 10.5 hotside. once you get more bolt-ons you'll be able to hold boost better.
Old Jun 17, 2009 | 04:58 AM
TommiM's Avatar
interesting. I am gonna do a boost leak test, but I also wanted to make sure I am not trying to diagnose something that is completely normal,heh. I have been trying to do a search on the perrin crank pulley, someone told me that due to it not having a dampener my engine could be pulling timing, reading knock from it.
Old Jun 17, 2009 | 05:07 AM
not dampening vibrations in the rotating assembly isnt enough for it to register as knock. only occurrence from an undampend unbalanced crank pulley is accelerated bearing wear. as far as doing a boost leak there arent any leak issues with your car. 20 is avg peak boost and 15 is avg boost taper by 6500 on a bone stock no-bolt ons 9....its sad. to reiterate what i said before once you start getting bolt-on's full exhaust,intake,uicp and ic you'll hold boost much better and reach peak boost your actually tuned at.
Old Jun 17, 2009 | 07:21 AM
Fast_Freddie's Avatar
Veteran: Navy
It never hurts to do a boost leak test every once in a while.
Old Jun 17, 2009 | 08:25 AM
TommiM's Avatar
Good news,thanks.. well not so great, boost taper sucks. But good to know im most likely ok. I have a oem crank pulley I want to swap back in this weekend. The specs are nice from the advertisements for the perrin piece, but it just seems better to have a dampened pulley, imo.
Previous owner had this car pretty much stock except for a turbo timer and a perrin pulley. Interesting selection of first mods,.
mrfred
537
Jun 20, 2022 09:50 AM
Mohannad
Cobb AccessPORT
Jul 11, 2020 05:40 PM
Kody Mills
10
May 13, 2017 12:52 AM
nor11384
Jan 1, 2016 06:50 PM
Shadowpriest
May 5, 2008 12:39 PM
