Oil pressure light flickers on at idle.
Old Jun 27, 2009 | 10:28 PM
compscibOi's Avatar
Just found this after searching. Mine does the same thing. It started doing it after I installed the Defi BF Amber Premium oil pressure gauge and sensor.
Only does it when the car is at optimal operating temperature and after I get off the highway and come to a complete stop or when I pull it in the garage.
My car has 41K miles on it and I change the oil religiously every 3k miles. I also have plenty of oil in it and it does it occasionally.
Old Jun 28, 2009 | 08:48 AM
GinNBoost's Avatar
Greddy Easycams? Lol WTF
Old Jul 26, 2009 | 08:28 PM
huevosrancheros's Avatar
https://www.evolutionm.net/forums/ev...d-problem.html
POW!!!!! Problem Fixed.
oil for evo is 5.4qts as per manufacutrer's manual.
Old Jul 31, 2009 | 06:16 PM
will05's Avatar
I have the hks 280 and was running royal purple in the car and it was doing it as well, then i changed to amsoil and i really dont see that much any more unless it is a really hot day.. Mine car did not start doing that unitl i put the cams in..
Old Aug 7, 2009 | 07:52 AM
mitsuevo803's Avatar
yeah dude....$300 they came direct from greddy brand new in box lol. lancershop i believe had a mess up in their computer system or somthing cause they were listed there a WHILE back for 299.95 lol.
the greddy 264's are actually more aggressive than the hks 272's. well i shouldnt say more aggressive but they're although theyre a shorter duration (obviously) then the hks 272s, both the hks 272 and the greddy 264 exhaust cams have the same 10.3 lift and the hks 272 intake cam has a 10.2 as opposed to the greddy 264 at 10.3 intake.
not that big of a difference, but hey for $300 for brand new cams...ill take em
Old Aug 11, 2010 | 08:30 PM
XcreatonX's Avatar
picked up a oem sensor for mitsu. I forgot to get a socket for it though. Found out that my prong was completely broke off. I think that might be the issue .
Old Aug 11, 2010 | 09:42 PM
L888Apex's Avatar
mine has been doing this for quite some time now but I always guessed it was the cams but I guess I'll have to try some of these tricks posted
Old Sep 3, 2010 | 08:14 PM
outtanowhere's Avatar
Sounds like a faulty oil pressure sending unit.Change it and then see if the problem still exists.
Old Mar 10, 2012 | 08:29 AM
ablan029's Avatar
this just happened to me. i replaced the oil pressure switch ($7 at autozone) and it solved the problem. it was a pain in the butt to get at since it's mounted on the block underneath the intake manifold...had to remove the uicp and squeeze through all the hoses and wires. don't forget the special socket and high temp silicon gasket.
Old Mar 10, 2012 | 08:31 AM
doghouse's Avatar
Originally Posted by BluByWho
It is your oil pressure sending swith. It happens on mitsus a lot, the part is usually in stock at your local dealer, around $35.00. You'll also need a special socket from autozone that is $10. The switch is located on the back of the block and can be changed with hand tools. I just did this last weekend.
same thing happen to mine and I installed a honda switch on the spot
CaptainSquirts
Jul 5, 2016 07:43 PM
deza3000
Oct 4, 2015 11:09 PM
KJS
Jul 26, 2014 02:05 PM
AustinG
31
Sep 2, 2012 06:16 PM
DevilDuck
10
May 23, 2010 03:35 PM
