I need help car wont start
Old Jun 19, 2009 | 01:46 PM
izabran's Avatar
ok i just had a clutch put in...
NOW THE CAR WONT START...
i re did timing... it has fuel and spark...
STILL WILL not start... ANY HELP????
Old Jun 19, 2009 | 01:49 PM
Evostacio's Avatar
damm this sucks someone help this guy
Old Jun 19, 2009 | 02:01 PM
izabran's Avatar
please LOL... im stuck i tried everything even re-uploaded my map thought the immobilizer kicked in... still no use...
Old Jun 19, 2009 | 02:09 PM
VRSF Tiago's Avatar
Have you checked the connections on the starter?
Old Jun 19, 2009 | 02:10 PM
Evostacio's Avatar
imstilltrying to think what it could be
evo8um's Avatar
what does it do when you crank it? does it try to pull over or not? it could be the timing is off?
Old Jun 19, 2009 | 02:24 PM
izabran's Avatar
the onnections are on...
it just cranks... it DOESNT turn over... i jus charged the battery...
still NOTHING...
when i first tried teh timing was off... one tooth forward past the line on the non mivec... and 2 teeth before the mark on the mivec... tried crankin nuttin...
now timing is fixed... STILL nothing...
Old Jun 19, 2009 | 02:34 PM
evo8um's Avatar
so you cranked the first time while the timing was off? if you did then i dont lknow if that could have effected now. but if you say you got fuel and spark i have no idea.
Old Jun 19, 2009 | 02:38 PM
evoIX15's Avatar
this.
Old Jun 19, 2009 | 02:43 PM
evo8um's Avatar
if the connections were off i dont think it with even crank over.
Old Jun 19, 2009 | 03:02 PM
VRSF Tiago's Avatar
Why was your timing off from doing a clutch install?
Old Jun 19, 2009 | 03:20 PM
srtboostin22's Avatar
check all your grounds
Old Jun 19, 2009 | 03:24 PM
izabran's Avatar
to be honest with you NO IDEA...
i mean i wwas turning the crank and it wasn't turning then out of no where when forcing it i heard like a popping sound so im guessing it was the belt skipping timing..
just did a compression test 2 left cylinders 30... bent valves anyone lol????
Old Jun 20, 2009 | 12:20 PM
prest0's Avatar
Plugs?
Old Jun 20, 2009 | 12:21 PM
prest0's Avatar
Err you checked for spark,.. disregard plugs
