Boost trails off after EPM Dump Install
Old Jun 19, 2009 | 01:54 PM
rawkus's Avatar
Hello all,
I used to be able to hold boost (21-22psi) from about 3700-3800 to redline. After I installed an EPM Dump and TME 6.5 turbo (ported and coated by MAPeformance) boost falls off to 18-19psi near redline. The car "feels" faster than before, but I can't 100% say for sure. The previous turbo was just a stock Evo 8 turbo. Could this be an effect of having less back pressure?
Dan
Old Jun 19, 2009 | 02:03 PM
Fast_Freddie's Avatar
Veteran: Navy
Which 02 housing did you have before? Also did you set the wastegate preload on either turbo?
Old Jun 19, 2009 | 02:08 PM
Evostacio's Avatar
humm very interesting
Old Jun 19, 2009 | 02:13 PM
sspaladin28's Avatar
Funny cuz when I had my MAP o2 dump my boost creeped so badly I couldn't run it
Old Jun 19, 2009 | 03:28 PM
bustriajb's Avatar
Wouldn't you need to re-tune after changing those parts?
Old Jun 19, 2009 | 03:36 PM
After two changes that major, you would indeed want a tune to maximize the setup and adjust for the new variables
Old Jun 30, 2009 | 07:43 AM
rawkus's Avatar
Completely forgot about this thread.
I was running a stock o2 housing before with 3" downpipe and exhaust.
I did adjust preload on the wastegate, but I want to double check after things have been driven a while.
And we are going to retune the car soon, awaiting a new Wideband to arrive. I will try and remember to keep everyone up to date.
Dan
Old Jun 30, 2009 | 09:07 AM
mrdevo's Avatar
Not having a tune and running a more eficient setup could lead to boost falling off more than before. You hear how people with with just a boost controller and tune can hold 20+psi to redline no problem, but the ones who are more modded can't hold it...its all about efficiency in every individual setup. Your turbo is making more power but not working as hard..
Old Jun 30, 2009 | 09:12 AM
sparky's Avatar
Try preloading the WG to 17-18 PSI. Are you running a cat or a catless exhaust?
Did your car´s original turbo have a 9.8cm turbine housing, whereas the new one has a 10.5cm housing?
Old Jul 1, 2009 | 08:30 AM
rawkus's Avatar
I am running with a cat and yes, I went from 9.8cm to 10.5cm. More updates soon.
Dan
Old Jul 1, 2009 | 02:16 PM
sparky's Avatar
Originally Posted by rawkus
Hello all,
I used to be able to hold boost (21-22psi) from about 3700-3800 to redline. After I installed an EPM Dump and TME 6.5 turbo (ported and coated by MAPeformance) boost falls off to 18-19psi near redline. The car "feels" faster than before....Could this be an effect of having less back pressure?
Based on my experience with porting my Green turbo and having seen the quality of porting done by MAP, I would say that yes, quite possibly that drop could be due to a decrease in backpressure.
MAP does excellent work judging from the little I've seen. They port the turbine discharge area of the turbine housing and this work if done properly can definitely reduce backpressure by about 3-4#. Reducing backpressure at the outlet improves the overall efficiency of the turbo due to a more favorable pressure differential between compressor and turbine.
Old Jul 1, 2009 | 07:09 PM
andrewzaragoza's Avatar
yes just like what the other people said, tighten up your preload. make sure you do this before you get a tune atleast you could get the full potential of your new upgrades.
Evolessfornow
23
Jun 3, 2011 10:57 AM
jnut24
Mar 27, 2011 09:03 PM
Q@EvoPowerMods
Feb 17, 2009 10:14 AM
Evo9"Miss Rose"
33
Dec 28, 2008 02:23 PM
03redtype-s
10
Oct 6, 2008 08:28 PM
