Coolant - What Are You Using?
Old Jul 7, 2009 | 05:41 AM
bbyevo8u's Avatar
whats water wetter?
Old Jul 7, 2009 | 06:02 AM
icrnk's Avatar
Originally Posted by bbyevo8u
whats water wetter?
Redline:
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
http://www.redlineoil.com/products_c...coolantFlash=1
Old Jul 7, 2009 | 06:09 AM
vboy425's Avatar
i you want to use about 20% of coolant to lube the water pump or u going to kill it. the rest add distill water. u can add Water wetter additive like BG supercool or Redline. Just remember those water wetter are not coolant replacement.
Old Jul 7, 2009 | 06:29 AM
bbyevo8u's Avatar
^^what?
can you get water wetter in autozone?
Old Jul 7, 2009 | 06:45 AM
MJ23FE's Avatar
Originally Posted by BerserkerX
Lol how did you know I didn't read it?
I read it now though! and it sounds like it could really work. That is why I switched to the ralliart cool thermostat. I was tired of the car climbing to high temps so I got that with water wetter and a radiator plate. It seemed to help quite a bit really.
So who is the Guinea that tries it on their car to see if it works? I am too poor for that ha ha.
Where did you pick up the ralliart thermostat? The radiator plate you are referring to is the one that sits on the rad support and not the plates they make that go over the exposed parts of the radiator where the fan mounts, correct?
-Jalal
Old Jul 7, 2009 | 07:30 AM
jid2's Avatar
I run straight distilled water in the Summer with a bottle of Redline Water Wetter and a touch of coolant. Just like Vboy suggested. In the winter I go back to regular coolant/water mix.
Old Jul 7, 2009 | 07:37 AM
icrnk's Avatar
^^what?
He meant:
Use about 20% coolant to lube the water pump or u going to kill it. the rest add distilled water. u can add Water wetter additive like BG supercool or Redline. Just remember those additives are not coolant replacement.
I just bought some last week at Advanced Auto. I've also seen it at Peb Boys. Oreily's may have it too. Not sure if Autozone or Napa carry the Redline brand. There are other brands like BG and Royal Purple. I'm just partial to Redline for this based on just the brand.
Old Jul 7, 2009 | 07:45 AM
dsevo's Avatar
FWIW, the water wetter bottles do say they can be run with water alone. I think running a little coolant definitely couldn't hurt though.
Old Jul 7, 2009 | 07:59 AM
bbyevo8u's Avatar
Originally Posted by icrnk
He meant:
oh thanks, i'm at 36k miles and my coolant is a nice bit below the low mark even when worm it might get to the low mark. i dont know if i should change the coolant out or just add to it? or should i just add the water watter and some distilled water
Old Jul 7, 2009 | 08:01 AM
eflove's Avatar
I use Toyota 100k mile pink fluid. I used to work for Toyota and had some around when I did the flush. It's nice stuff and it real easy to spot a leak.
Old Jul 7, 2009 | 10:15 AM
Hioffcr's Avatar
From: Killeen, Tx via Fayetteville, NC via Worthington, OH
After reading a couple of other threads.....I am now wondering if anyone is running Honda (blue) coolant. Or BMW coolant......as my wifes car runs cool as ice.
Old Jul 7, 2009 | 07:47 PM
Raceghost's Avatar
^^ Look at the Evans cooling site for a detailed description. http://www.evanscooling.com/index2.html Much higher boiling point, etc.
Drilling a hole in your cap causes a higher boiling point? I knew that a higher pressure one did but I didn't think drilling a hole would. That's interesting.
You didn't read the Evans Cooling page, did you?
The coolant itself has a higher boiling point, and thus does not need a pressurized system, like normal antifreeze does to try and keep it liquid instead of vapor. That's why there's a hole in the cap -- there's no need for pressure in the system...
So I have looked on there, and maybe I am missing it...we have to drill a holw in the radiator cap to utilize this?
Do you have any experience utilizing it in the winter time? I would really like to use this stuff, and I am doing my coolant flush etc, within the next week.
So If no one has had experience, then maybe I will call them. You may have found your guinee pig on the evans if I like what I hear.
Old Jul 7, 2009 | 07:53 PM
rush63's Avatar
Changed my coolant 2 days ago at 13,974 miles on the car. I used a gallon of Prestone, 2 bottles of Redline Water Wetter and the rest is CVS disltilled water.
Old Jul 8, 2009 | 09:05 PM
BerserkerX's Avatar
-Jalal
Got the cool thermostat from Lancershop.com. I think that they have raised their prices on it. I got mine originally with the greddy radiator plate for like 90. It was like 40 for the plate and 50 for the thermostat. Yeah it sat on top of the mounts and diverted the air to the radiator. It really did work. Import tuner just did a test on those with a S13 240 and it dropped the temps considerably.
From what i understand the coolant is a not pressurized system. You can either drill a hole inside of your radiator cap or order their coolant, pump, radiator, and cap. Basically by drilling the hole inside of the cap you eliminate the pressure.
Getting rid of the pressure and water makes it so that bubbles don't form along your cylinders and head in the water jacket. Its called nucleatic boiling. Basically when a bubble forms there is no coolant touching that part of the metal. So it creates a "hot spot" in the cylinder. That can cause detonation which causes knock. So it sounds like it could work. I just don't have the money to do it lol. I am trying to buy myself a TDI get ready for those 4 and 5 dollar a gallon gas prices ha ha.
kyoo
220
Dec 11, 2018 01:32 PM
ant_turbo
Aug 17, 2011 07:12 AM
ant_turbo
Jan 3, 2009 12:44 PM
Mr. PSSsSt
May 21, 2008 08:16 AM
Ant1
Jan 31, 2008 08:06 PM
