snapped a headstud...
Old Jul 8, 2009 | 11:21 PM
SeanC's Avatar
Originally Posted by PVD04
If you find that your other studs may have been over-torqued at any point in their life (i.e. torque wrench being off, previous owner/shop overtightening) then you should replace them all as they all may have some plastic deformation and will not provide proper sealing pressure.
Exactly. Also, the lubricant will effect the strain on the fastener too. Replace them all.
Old Jul 8, 2009 | 11:32 PM
xRoguex's Avatar
Originally Posted by S2kracka
Was this the first time you've ever torqued that certain set of ARP's? If you reused them, then go ahead and replace them all and use a new head gasket since they crush and can only be compressed once. I recently reassembled my friend's car and torqued the studs to 93 ft/lbs in increments (30-60-80-92-run the car to break in the cams-93) using ARP moly assembly lube on the nuts and washers while screwing the studs into the head dry.
That torque settings method -- Is well simply put - A bad idea.
3 steps are all you need and the last step should be 1.5+ times the second step.
IE - 30-45-85 of if you like 95 go 35-50-95.
This allows you to get a more true torque/clamp load. Rather then getting inaccurate readings from the coefficient of friction of starting the twist. If the torque wrench only turns a HAIR and then clicks.. your readings will be more inaccurate then if you finish with a 1/4 twist ending in the click. Indicating that more then likely your torque was based on clamp load - not twisting/screwing friction.
marksae
61
Aug 13, 2017 12:30 PM
evokid511
May 6, 2012 02:04 PM
lemmysports2
Apr 5, 2012 06:12 AM
lemmonhead
Future Lancer / Evo Models
98
Aug 21, 2007 08:28 AM
hotrod2448
Oct 8, 2005 01:10 PM
