ETS front mount intercooler
Old Jul 11, 2009 | 02:23 PM
BRN-EVO's Avatar
Hello guys,
I'm going to buy the ETS front mount intercooler with the lower pipe. however, I'm not really sure what size should I buy, 3" or 3.5"? My car has a TBE and K&N drop in filter. What is the stock intercooler's size?
Thanks
Old Jul 11, 2009 | 02:30 PM
BLKCarbonEVO's Avatar
Dude, I would go with the 3.5" for sure! What are your future plans?
Old Jul 11, 2009 | 02:33 PM
BRN-EVO's Avatar
I would probably just get a manual boost controller, tune the car and set it at not more than 21 psi.
Old Jul 11, 2009 | 02:38 PM
detroit pistins's Avatar
ya i would go with the 3.5'' in case u wanna heavily mod the car down the road. but check and see if u would need to modify the crash bar , i heard it was either the 3.5'' or the 4'' cores need some modifications.
Old Jul 11, 2009 | 02:53 PM
Its on the 4". One thing to remember is always get something you can grow into because you don't want to end up buying another one down the road.
You can def run more than 21lbs. On pump 92, most the guys up in the NW are running 25lbs-27lbs on stock turbo thanks to the greatest tuner ever, Aaron at English Racing. That's will 0 knock count too!
Old Jul 11, 2009 | 02:56 PM
Boricua_Evo's Avatar
If your goal is withing 350-600, you can stay with the 3", but for 100 dollars more, you can get a 3.5"...
Old Jul 11, 2009 | 03:08 PM
whitey4d's Avatar
No smaller then a 3.5. a 3" is barely an upgrade over stock. If your gonna spend the money on a new IC I couldnt justify spending the money to get anything smaller then a 3.5".
Old Jul 11, 2009 | 03:12 PM
BRN-EVO's Avatar
is the stock intercooler 3"?
Old Jul 11, 2009 | 03:19 PM
gsrboi80's Avatar
No its not
Old Jul 11, 2009 | 03:26 PM
bbyevo8u's Avatar
if your going to stay under 400whp then def 3" if your not sure then go bigger!
Old Jul 11, 2009 | 03:35 PM
Originally Posted by BRN-EVO
Hello guys,
Thanks
PM sent... Dude def go bigger! You need a 3.5" or a 4" if you plan to go over 400 on pump, it will help you achieve that. The only down side to a large intercooler is the turbo lag but its not that bad. I couldn't tell between a stock and 3.5".
Old Jul 11, 2009 | 04:12 PM
BRN-EVO's Avatar
The thing is Im not in NW, Im in Bahrain where there is no true Evo tuner and we have only 91 octane!
Old Jul 11, 2009 | 04:19 PM
BRN-EVO's Avatar
So I see that most of you recommend the 3.5". One last thing, do you recommend buying the 3.5" even if I keep it under 350whp? I mean is it benefitial?
Thanks alot guys, I have no one to ask except you
Old Jul 11, 2009 | 04:32 PM
Yes
Old Jul 11, 2009 | 04:33 PM
bbyevo8u's Avatar
if your staying under 400whp then its overkill to get the 3.5!!
