Car running lean.
Old Jul 16, 2009 | 08:14 PM
PineappleMonkey's Avatar
Car running lean.
Around 3500-4000rpm the car runs lean and boost drops from 20 to around 5psi. I've bypassed the MBC and ran straight turbo/wastegate with the solenoid disabled, in the tune the cutoff is higher anyways then this so it shouldn't kick in.
I think the problem is either this FPR or a timing issue with the car. I'd like to start testing both asap.
I've so far:
Checked the tune
Boost
Wastegate
Plugs
Boost Leaks
Compression is fine
Fuel pump ( two of them/walbros)
Boost controller
Injector duty is good
Old Jul 17, 2009 | 12:46 PM
ArmedEscort's Avatar
Interested in what happens.
Old Jul 17, 2009 | 01:03 PM
Teal2nnr's Avatar
Hummmm **** i'd like to know the anwser to this.
Old Jul 20, 2009 | 01:20 PM
So I checked the voltage to the pump, it read 9.5v and jumped to 12.5 as soon as I rolled on. Thoughts?
plokivos
84
Jun 7, 2017 11:25 AM
tsidrift1
May 19, 2016 06:19 PM
RS200
Oct 1, 2015 07:27 AM
wyattv
Dec 17, 2014 06:21 AM
1QWKEVO
Aug 1, 2003 09:57 AM
