Car diagnosis?? Please help
Old Jul 18, 2009 | 12:41 PM
vxevolutionxv's Avatar
Ok so I resently installed an exhaust manifold, O2 housing, downpipe cutout and new plugs. When i start moving it sounds like im running on 3 cylindersand after like 2500-3000 rpm the car runs normal. Also when I hit about 16 psi and on it starts breaking up and ****. It threw a random multiple misfire code. Tring to fix the problem i replaced coils, wires, and plugs. Still doing it and im afraid to drive it.
My battery dies very fast if i leave the car not started with the lights on. Will a bad battery be causing the misfires?
Old Jul 18, 2009 | 01:40 PM
evodood's Avatar
What'd you gap your plugs at?
Battery= posibility
Old Jul 18, 2009 | 01:45 PM
its not the gap i have em at like 22-23. Any other help!!!???
Old Jul 18, 2009 | 03:27 PM
evosean's Avatar
vacuum leak possibly around one of the parts you installed
Old Jul 18, 2009 | 03:28 PM
evosean's Avatar
after first starting, does it run better than say after 5 mins. of running?
Old Jul 18, 2009 | 03:34 PM
smokedmustang's Avatar
What manifold is it? Is that leaking? I would put stock stuff back on, till it runs good, and then you know the problem.
Old Jul 18, 2009 | 07:50 PM
evodood's Avatar
forget to plug in your MAF by any chance? I've forgotten a few times now
Old Jul 20, 2009 | 09:07 AM
The MAF is pluged in and its not a boost leak i have a engine code for multiple random misfire. I changed coils and plug from my buddies car and it ran fine. The only thing i can think of is gettin new coil boots...ill let u know if i need any futher assistance. Thanks
Old Jul 20, 2009 | 10:29 AM
mini_evo's Avatar
Yes, a bad battery will cause this problem. And while you are at it, check your alternator to make sure it is running properly.
Old Jul 20, 2009 | 09:45 PM
mitsuv's Avatar
Do you have a pic of your coils ?
Do you have correctly tighten the plugs?
Do you tried to changed them? ( the old ones)
A worn battery would make harder engine starting but then the alternator regulates a 14V voltage
Old Jul 20, 2009 | 10:04 PM
NeoGearX's Avatar
Do you have EvoScan (or another logger) it might give better insight as to what is happening.
Most will probably not agree, but I have a more conservative approach to mods and to me it seems like you might have changes too many things at once which might make it more difficult to track down.
johnashton11
11
Sep 13, 2019 01:23 PM
mrhussain
24
Feb 16, 2017 08:01 AM
NYREDEVO
Nov 13, 2008 06:04 PM
kouzman
20
Jul 13, 2008 08:02 AM
DDTPro17
Jun 24, 2008 09:16 PM
