running hot
Old Jul 20, 2009 | 12:08 PM
03evo8kevin's Avatar
running hot
ok well i had an accident in my car about six month ago and now that i have worked on my car i replaced the radiator(mishimoto) the whole cooling and ac fan assemblies new ams intercooler u kno all that good stuff well i took it driving for the first time and it is getting hot and my cooling fan is not coming on i replaced the temp sensor and that did not helped i checked the fuse and that did not help either i noticed on my cooling fan motor or switch there are 2 plugs that plug into the bottom of it and then there is a place to plug something in off to the right side of the motor/switch but no plug any ideas on wut it is?
Old Jul 20, 2009 | 08:56 PM
YoungEvolution's Avatar
Thermostat or headgasket?
i had coolant problems and thats what it ended being
Old Jul 21, 2009 | 06:33 AM
just put in a new therm and nothing wrong with the head gasket as far as i can tell i mean u wuld be able to tell just simply by looking right? plus im not loseing coolant anywhere except for the overflow tank
Old Jul 21, 2009 | 11:58 AM
max4rw's Avatar
I had a cooling issue temp gauge would sky rocket in hard acceleration when I let off the gas it would settle back to normal in about 30 seconds. fan would also come on all the time.... I put a new thermostat in and problem solved! I feelt very lucky! if you have no radiator leaks and you replaced your thermostat and still getting the same problem it sounds like your next step would be a compression test. you also might wanna try and drain and replace the fluid... could be air bubbles good luck hope this helps!
Old Jul 21, 2009 | 02:31 PM
barneyb's Avatar
Well, the OEM fan is multi speed and has a controller that sits right beside it. First the fan or fans need to run and second the OEM fans will move more air than any aftermarket fans I am aware of.
Old Jul 22, 2009 | 09:32 AM
compression is good and its all new fluid and wut not cause i just put a brand new radiator in and it is the oem fan
lghtngyello03
10
Jul 22, 2016 03:26 PM
jason42003
Jan 30, 2014 11:10 AM
414Evo8
Jul 18, 2013 05:15 PM
Dambay
10
Jul 9, 2013 03:30 PM
utggevox
Jun 10, 2012 04:30 PM
