TTP's FullBlown E85 upgrade and dynotesting on the stock block 571whp/481wtq!
Old Jul 22, 2009 | 09:28 AM
  #46
dmoevo's Avatar
Originally Posted by s.e.a.n.
I wouldn't compare it to race gas, race gas is rated at 110 and higher. E85 is 105 right.
I don't think its right to compare it to regular 93 octane
performance wise as in gains.
and of course pricing like mike said 5 gal/$75 or $30 for a full tank?
Old Jul 22, 2009 | 09:32 AM
  #47
SpoolnupTuning's Avatar
Originally Posted by project_skyline
How'd you get 1650's to work on the stock ecu, I though the biggest you could do was 1450's.
dsm25psi with the stock ecu hp record has been running fic 1600s for over 9 months now!
Old Jul 22, 2009 | 09:40 AM
  #48
evoracingstar's Avatar
why do u need such a big injectore to run e85?? thats crazyy
Old Jul 22, 2009 | 11:16 AM
  #49
CO_VR4's Avatar
While E85 does require somewhere around 30% more fuel per HP than gas, the other reason big injectors are needed is that he's making beaucoup HP Lots of air from that HTA86 requires lots of fuel to match.
Old Jul 22, 2009 | 12:52 PM
  #50
Zeitronix's Avatar
But E-85 "acts" like 110. Octane is not everything. E85 evaporation helps too cool down stuff reducing chance of detonation. Kind of like meth does.
Old Jul 22, 2009 | 12:56 PM
  #51
diiirk@AwdMotorsports's Avatar
e85 also outperforms c-16,q-16,110... all of which cost ~$15/gallon
Old Jul 22, 2009 | 12:59 PM
  #52
Zeitronix's Avatar
Originally Posted by GST Motorsports
...and it's 14.7 AFR / 1 Lambda no matter what fuel on a gasoline AFR/Lambda gauge like the Zeitronix.
Bryan is right. The Zt-2 is a LAMBDA meter. Displayed AFR, is converted lambda into AFR for petrol. So if you use E85 the Zt-2 still reads lambda and you can use converted petrol AFR number for your tuning pleasure. It's not a "real" ethanol AFR as molecular fuel weight is completely different, but who knows what % of E is in the tank any way. Even if using Zeitronix ECA you would have to calculate a stoichometric air/fuel weight for a given mix you are using right now. So using lambda is the most practical. If you do not speak lambda, then use converted petrol AFR. simple
Old Jul 22, 2009 | 05:31 PM
  #53
project_skyline's Avatar
Lol I must have missed that.
Good job ttp. Dont blow it up now.
Old Jul 22, 2009 | 05:47 PM
  #54
GST Motorsports's Avatar
1600's seem to work fine on E85, but are a bit of hassle to get to run on pump gas because of the low IDC's at idle and low loads.
It all depends on each persons perception of "running correctly".
Old Jul 24, 2009 | 05:14 PM
  #55
coastevo's Avatar
As for the price of E85 at the station.. Anyone consider distilling thier own ethanol and running 95-100 precent E? I'm planning on building a still for this exact purpose and buying corn feedstock to make E95 (or 100 if I use a molecular sieve to filter the extra water in the blend) for less than 50cents a gallon. If you live close enough to a saw mill you can take the saw dust off em and make ethanol from wood as well by using a relativley simple process described here: http://www.green-trust.org/sawdust_ethanol.htm
In this case if you could get free sawdust from the mill you could drive a 572+whp car like the one aforementioned for maybe 10 or 20 cents a galllon after that initial startup investment in building your fermenting containers/still and buying the enzymes(which if done smart could be quite cheap by raiding your local junkyard or garbage lot).
This is also legal if you apply for a free permit from the Bureau of Alcohol, Tobacco & Firearms, but if you go the legal route you will have to distill outside, have the possibility of them coming by and inspecting your operation, and also using some kind of additive to keep the alcohol from being "beverage grade"; usually by just adding some regular fuel(the ethanol must be water free to do this or the gasoline can seperate from the rest) or a small amount of methanol (no concern with some water in the mix).
Also it should be noted that going the legal route can make you elligable for some tax rebates for driving an ethanol car or even for selling ethanol fuel.
Not to even mention how sweet it would be to have a 600hp daily driver EVO that ran on corn and sawdust!
Old Jul 24, 2009 | 07:55 PM
  #56
TTP Engineering's Avatar
Funny you mentioned it... We hit 600whp today on the stock throttle body and Magnus V5 intake manifold. Review to come soon.
Old Jul 24, 2009 | 08:14 PM
  #57
D420mac's Avatar
when speaking of the switch between maps do you actually have a switch or do you have to use your computer? I have an AEM in my IX I'm thinking of switching to E85, but I don't want to have to lug the computer around everywhere in the car if I need to switch fuel.
Old Jul 24, 2009 | 08:16 PM
  #58
An illuminated switch indicating the successful switch from 93 octane and injector scaling / latency, ignition timing and fueling maps to the second set of all of the preceding maps.
Old Jul 24, 2009 | 08:18 PM
  #59
D420mac's Avatar
mine is a 711 hp daily driver, on 93 and alcky. Also I believe E85 is 110 octane.
Old Jul 24, 2009 | 08:19 PM
  #60
D420mac's Avatar
I'm hoping with the E85 I can get closer to the 800 whp range, in a daily driver.
