Need Help on tuning the APEXi AVC-R
Old Oct 10, 2003 | 11:58 AM
A-SPEC's Avatar
Question Need Help on tuning the APEXi AVC-R
Just got the APEXi AVC-R & SAFC-II on my Evo, after the extensive reading on the manual, still have no clue to tuning it fast.
My car has a cone air filter (airbox removed), otherwise all stock. I am particular not clear about the F/B speed, Learn Gear, Start Duty, etc.
I set it at 1.5kg/cm2 boost level starting from 2500rpm and taper down to 1.3kg/cm2 at 7000rpm. I can feel the car is smoother than before and it lost the turbo lag (i kind of miss that!) The car feel really fast on 3rd & 4th gear. But on 1st & 2nd, the car seems has little improvement over stock.....
I have not tune the SAFC-II yet, but I would like to get the boost level set before i go into the SAFC-II.
I am running 91 octane all the time.
Also, anybody knows about the reading on the A/F what is the higher number means (1-20) and what is the lower number means? I guessed the 14-16 is the optimal range.
Please help!
thanks
EvoDan2004
28
Oct 25, 2013 07:58 PM
CrackerJackToy
Aug 11, 2007 06:54 PM
Marteinn
Mar 17, 2007 04:09 PM
webguy330i
Sep 18, 2003 07:37 PM
ZUES
May 26, 2002 08:14 PM
