should i do e85 or not !
Old Jul 27, 2009 | 10:21 PM
dmoevo's Avatar
price per mile im actually saving a little comapred to pump gas,93
Old Jul 28, 2009 | 07:00 AM
rawburt's Avatar
Love this stuff
Old Jul 28, 2009 | 07:13 AM
evokid511's Avatar
Originally Posted by Dustydrifter
E85 is the dumbest thing i have ever seen. it is less efficient than gasoline, which is why you have to upgrade your injectors. less fuel economy with slightly cheaper and way less available fuel source means you converting to ethanol will give you a power increase and more money in your gas tank just my opinion
idk why you can say that ive been on e85 now for about 3 months and my miles per tank has only gone down about 20 miles to a tank and for a ga thats 70 cents cheaper a gallona nd going down. and it gives awesome power and cleaner is just beyond me why if its avaible by you you wouldnt switch to it
Old Jul 28, 2009 | 07:19 AM
Evo_TK's Avatar
Do it, all your going to need is some 1000cc injectors and walbro 255 fuel pump then let the fun begin
Old Jul 28, 2009 | 07:20 AM
justa4banger's Avatar
e85 is just sick...its so damn knock resitant...i have done street racing back to back pulls on the stock ic and still not knock
Old Jul 28, 2009 | 07:35 AM
EVILBLOODBROTHA's Avatar
So you dont have the 1000 cc injecters and the 255 pump? I need to know, I want to just fill it up once and see if I like it
Old Jul 28, 2009 | 08:05 AM
dbsears's Avatar
Can't do that Stock turbo really needs a minimum of 1000cc and a walbro if your running any decent amount of boost. You will need a completely different tune also.
Old Jul 28, 2009 | 08:39 AM
dambikeracer's Avatar
DO IT ALREADY! WALBRO 255, PTE 880's, AND A GOOD TUNE GAVE ME 79WHP AND 89WTQ AT 29.5PSI!!! I DRIVE 1500-2500 MILES A MONTH AS MY DD AND STILL DRAG EVERY CHANCE I GET! I WENT FROM 13.1 IN THE 1/4 MILE TO 11.7 FROM E-85! BEST AND CHEEPEST UPGRADE BAR NONE!
Old Jul 28, 2009 | 08:49 AM
gen3eclipsegt's Avatar
theres no reason to not do it only reason would be how far away you live from a gas station that had it everything else is all +++++
Old Jul 28, 2009 | 09:13 AM
number 8's Avatar
What about road trips? There's one station right in my town but, thats it. I could get away with that 90% of the time, its the other 10% that scares me. Heck, I've come close to getting stuck looking for 93 oct. that I'm tuned for.
Old Jul 28, 2009 | 10:13 PM
big block ix's Avatar
5-gallon plastic gas jugs
Old Jul 28, 2009 | 10:18 PM
NsinEvo8's Avatar
^ that, and map switching is your friend..
Old Jul 28, 2009 | 10:54 PM
project_skyline's Avatar
LOL
Don't hate cause you dont got it.
Old Jul 28, 2009 | 11:03 PM
LANCEREvo9MR's Avatar
do it its the best bang for your buck and if ure worried about running out, map switch like im doing 468 whp and 380 lb of torque on a gt3076r well worth it o and stock bottom end
Old Jul 28, 2009 | 11:45 PM
yahu's Avatar
OP, totally do it if readily available! As others have said, keep a 93 map handy in case you need it, but otherwise run ethanol!
Scheides, why have you gone back to pump plus meth? Since you have the aquamist, did you ever try e85 plus meth? Just curious.
