Evo IX Vac question
Old Aug 1, 2009 | 07:11 PM
cpages2's Avatar
Evo IX Vac question
Does anyone know where I can find a document that shows where all the vac lines should be run on my engine?? I was doing some work on it and noticed a few lines pinched off by screws (F'ing previous owner).
Or if someone has some detailed engine pics they can send me.
I would like to go through it tomorrow and check each one and make sure its run to the proper place.
Thanks in advance.
- Mike
Old Aug 1, 2009 | 09:44 PM
chaotichoax's Avatar
under the hood there is a sticker
Old Aug 2, 2009 | 07:52 AM
cpages2's Avatar
CF hood, no stickers
Old Aug 2, 2009 | 08:02 AM
Kracka's Avatar
You could fix it the easy way and just eliminate all your emissions systems. If my Evo where here with me now I'd go take a picture of the underhood label for you.
Old Aug 2, 2009 | 10:22 AM
cpages2's Avatar
wont that have bad effects??? For instance I have a Forge MBC and I always question if bypassing the Boost Solinoid is causing me issues
Old Aug 2, 2009 | 11:47 AM
searching works too...I searched "vacuum"
this was the first result
https://www.evolutionm.net/forums/ev...e-routing.html
Kyruuu
Oct 29, 2015 01:44 AM
NexusEvoIX
Sep 30, 2015 02:20 PM
jcsbanks
Mar 18, 2009 07:12 AM
HobieKopek
Lancer Engine Tech
19
Jan 6, 2006 05:19 PM
woodc
14
Jun 2, 2005 05:38 AM
