Clutch recommendations
Old Apr 30, 2010 | 11:44 PM
  #31
casper980's Avatar
Originally Posted by btownsoccer22
I'm going to go carbonetic twin
Carbon clutches from what I am told should be used for purpose built race cars only as they need lots of heat to work properly. Daily driver will ruin that clutch quickly, again from what I am told.
Old Apr 30, 2010 | 11:53 PM
  #32
casper980's Avatar
Originally Posted by Spish
Yeah, but why pay 1500ish for a clutch that can hold 800hp when you'll never go over 400? Throwing expensive parts at an evo will not always make it faster, just because it the most expensive doesn't necessarily make it the best.
Because it will last 3x longer than a $600 one, and is actually easier to drive (read: less grabby, softer pedal feel) than an ACT HDSS, doesn't lock you out at 6500 rpm and will afford most of us enough holding power that we will never need another clutch. The most expensive (i think) is the carbonetic triple plate ($3000) which is a race only clutch. The reason most of us are fanboys of the Exedy is because we have experienced the issues, communicated them to each other and came up with the best solution.
Old May 2, 2010 | 08:13 PM
  #33
divine_evo's Avatar
I have installed the ACT HDG6 around 59,xxx miles. I'm currently right below 67,000 miles. The car drives fine. I haven't done any hard launches from a dead stop but from a roll I haven't experienced any high rpm lockout. Actually ever since I changed the clutch I haven't had any tranny grids while shifting. Because the clutch grabs harder than stock and is a 6 puck instead of a full face it does require a bit more pedal work when coming from a stop on a hill. To be fair my girl is 5 feet tall and can drive the Evo just fine on hills. She hasn't complained of the pedal being any stiffer than stock either.
I also installed the clutch with my brother, who is an ASE certified technicain, in a house hold garage. We changed all the fluids for the transmission, transfer case, and differentials. We did not change the clutch fluid. After the install my brother adjusted the pedal height because the stock height was not fully disengaging the clutch. If high rpm lockouts occur it is a good idea to check the pedal height and see if the clutch is fully disengaging when the clutch pedal is pressed.
Originally Posted by detroit pistins
for those that ended up getting any of the act clutches, any feedback on the shifting smoothness, high rpm lock outs, roughness on the tranny...etc?
Thanks
Old May 2, 2010 | 08:52 PM
  #34
Werd's Avatar
I have the ACT street disc in right now with about 17k miles and probably around 30 launches on it and it's still up great at about 380whp. If installed and adjusted properly it's a great clutch.
Kasey
11
Jul 24, 2014 11:29 AM
bluegsr
Apr 23, 2011 03:30 PM
PersianEVO
Jan 25, 2011 08:40 PM
BootScraper88
29
Aug 22, 2008 07:51 AM
awddyno
12
Jun 5, 2006 06:13 PM
